Moments - How to Calculate Tension in a Cable to Supply a Given Moment?
  • Thread starter Thread starter zrome
    Confused Moments
The discussion revolves around calculating the tension in a cable required to supply a specific moment about a point O while raising a pole. Participants explore the application of moments in physics, particularly focusing on the geometry and trigonometry involved in the problem.
  • Homework-related
  • One participant states the problem involves determining the tension T in a cable that must supply a moment of 72 Knm about point O, using the equation M = Fd.
  • Another participant explains that the moment of a force can be calculated using the perpendicular distance from the line of action to point O, suggesting the use of trigonometric functions to find the angle.
  • A different participant attempts to apply the sine of the angle to calculate T but arrives at an incorrect conclusion, indicating confusion about the trigonometric relationships involved.
  • Some participants suggest drawing a right triangle to better understand the relationships between the sides and angles, emphasizing the use of the tangent function to find angles or sine values without needing to know the angle itself.
  • One participant expresses gratitude for hints that helped clarify the geometry of the problem, indicating progress in understanding the necessary calculations.
Participants generally agree on the need to use trigonometric functions to solve the problem, but there is no consensus on the correct approach or the specific calculations required to arrive at the correct tension value.
Some participants express uncertainty about the angle involved and its implications for the calculations. There are also indications of missing assumptions related to the geometry of the setup and the relationships between the forces and distances.
This discussion may be useful for students or individuals studying mechanics, particularly those interested in understanding the application of moments and trigonometry in solving physics problems related to tension and forces.
zrome
"In raising the pole from the position show, the tension T in the cable must supply a moment about O of 72 Knm. Determine T."
M = Fd
d = 12sin(30) = 6m
T = 72/d
==> 12m
I do not know what I am doing wrong here. I'm assuming there is a problem with "12sin(30)" but I checked atleast 3 times and I still get the same eq. Please assist in any manner possible. Thank You in advance.
The moment of a force about a point O is the force times the perpendicular distance from the line of action of that force to the point O (M=F(d_perp)). Alternatively, the moment of a force about point O is the force times the distance from the point of the application of the force to point O, times the sine of the included angle between the two (M = rF sin theta = 30Tsin theta in this example). This becomes a geometrry/trig problem, where you must determine theta using the appropraite trig functions (as in using the law of sines and cosines, for example).
Now I'm not too sure if I understand you correctly here, but what I make out of your response is that the angle between, I believe it to be 30 degrees; you take the sin of the angle and then multiply that by the force, in this case T.
Doing that I arrive at the conclusion that 30Tsin(30) = 72 and solving for T results a 4.8 knm
I see the answer is wrong and am still unable to make out how to correctly solve this problem. Unfortunately I have a quiz on this material tomorrow evening at 6 and I need your help in trying to understand how to do this problem, for which the author of the book decided not to give the EDIT: workto.
The final answer is 8.65 knm. Could you kindly walk me step by step through the problem so that I can clearly understand how it is done? (I agree my trig is horrible)
Hi zrome! :smile:
zrome said:
… the angle between, I believe it to be 30 degrees; you take the sin of the angle and then multiply that by the force, in this case T.
Where do you get 30º from? :confused:
Hint: draw the vertical line from the top of the cable to the ground … so you have a right-angled triangle, and you want to know the sine of one of the angles. :wink:
That's a good hint by tiny-tim, to get the height of the vertical line. And, you can compute the horizontal projection of the pole on the ground, right? After that... Hint: Use definition of tan to compute an angle.
nvn said:
… Use definition of tan to compute an angle.
Hi nvn! :smile:
Actually, we don't need to know the angle …
we only want its sine, whch we can get from the sides of the right-angled triangle (and Pythagoras) :wink:
tiny-tim said:
Hi nvn! :smile:
Ya computed the vertical line and was able to see the big triangle I was missing. Thank you for all the help.
14K
11K
