Proton speed needed to circle the earth
The discussion focuses on calculating the speed required for a proton to orbit the Earth at an altitude of 1550.0 km above the magnetic equator, given Earth's magnetic field intensity of 4.19 × 10-8 T. The relevant equation used is r = m*v/Q*B, where r is the radius of the orbit, m is the mass of the proton, v is the velocity, Q is the charge of the proton, and B is the magnetic field strength. Participants confirm that the approach to solving for velocity is correct, emphasizing the importance of using accurate values for mass and charge in the calculations.
  • Understanding of circular motion in magnetic fields
  • Familiarity with the equation r = m*v/Q*B
  • Knowledge of the mass and charge of a proton
  • Basic principles of electromagnetism
  • Calculate the radius of the orbit using Earth's radius and the given altitude
  • Determine the mass and charge of a proton for accurate calculations
  • Explore the effects of varying magnetic field strengths on proton motion
  • Investigate practical applications of protons in magnetic fields, such as in particle accelerators
Students in physics, educators teaching electromagnetism, and researchers interested in particle motion in magnetic fields.
mba444
Assume that Earth’s magnetic field is every-
where perpendicular to the path of a proton
and that Earth’s magnetic field has an inten-
sity of 4.19 × 10−8 T.
What speed would a proton need to achieve
in order to circle Earth 1550.0 km above the
magnetic equator?
Answer in units of m/s.
r=m*v/Q*B
r=(r Earth + r given in the question )
i solved for v but I am not sure if what I am doing is correct
You are in right track.
thanX
