Balloons in a Car: The Science Behind Why They Move Forward When You Take Off
  • Thread starter Thread starter yakabod
    Car
The discussion revolves around the behavior of balloons in a car during acceleration, specifically why they move forward when the car takes off. The subject area includes concepts from physics related to buoyancy, pressure differentials, and inertia.
  • Participants explore the relationship between the car's acceleration and the movement of balloons, discussing pressure differences and buoyancy. Questions arise regarding the assumptions made about the type of gas in the balloons and how that affects their behavior. Some participants also consider the effects of inertia and pressure gradients on the balloons' movement.
The discussion is active, with various perspectives being shared. Some participants provide insights into the mechanics of how balloons behave under different conditions, while others question the assumptions about the gas used in the balloons. There is no explicit consensus, but productive dialogue is ongoing.
Participants note that the behavior of the balloons may differ based on whether they are filled with helium or air, and there are mentions of personal experiments conducted to observe these effects. The discussion acknowledges the complexity of the forces at play and the need for clarity regarding the conditions assumed in the problem.
yakabod
You are in a stop light and you have plenty of balloons in the back of your car. The light turns green and you proceed all the balloons move forward. Why when you take off in a car the balloons move forward?
Thanks a lot to whoever answers :)
The forward acceleration of the car causes a high pressure in the rear of the car and a low pressure in the front of the car, thus the He balloons float to the front of the car.
Another way of saying the same thing: The balloons are lighter than air (did you notice that FrankR assumed Helium balloons even though that was not specifically stated- if your balloons are blown up with air this won't happen) and so have less inertia than the air in the car. The air moves backward pushing the balloons forward.
You can do the same thing in a turn. In an American car if the helium balloon is floating above the front passenger seat and you take a left turn, the balloon slaps you in the face...provided the right window is not open!
:wink:
Creator
Sure it will... (won't it?)
The innards of the balloon are completely separate from what's going on outside.
When the car accelerates, there is an uneven pressure distribution on the outside of the balloon, which pushes it to the front of the car.
How will the the forces sum to zero if you've got air in the balloon, when they won't if you've got helium in it?
You don't necessarily need helium filled balloons. It works with air filled balloons as well, as long as there is a buoyant force on the balloon caused by a pressure gradient in the car, since the pressure in the balloon remains constant. I've actually tested both helium and air filled balloons, I barrowed balloons from a kid while riding a car to test a physics principle. I found it actually works better with air balloons, the He balloons tend to stick to the roof of the car, with static electricity and friction because they remain stuck to the roof if you don’t grab them. Saying they're filled with He helps to understand the concept. Just understand where the buoyant force comes from and it's fairly easy to grasp.
12K
  • · Replies 22 ·
