What Is the Solution to the Mathieu-Type Equation with Operator Cos(d/dx)?
  • Context: Graduate
  • Thread starter Thread starter iver
    Function
The discussion revolves around the solution to the Mathieu-type equation involving the operator cos(d/dx). Participants explore interpretations of the operator and its implications for solving the equation, which is presented in the context of differential equations and series expansions.
  • Exploratory, Technical explanation, Debate/contested, Mathematical reasoning
  • One participant questions how to solve the expression cos(d/dx)f(x), noting that the angle is an operator while the function f(x) is separate.
  • Another participant suggests that cos(d/dx) can be expressed as a Taylor series expansion involving derivatives of f(x).
  • A different interpretation is proposed where cos(d/dx)f(x) is understood as cos(df/dx), linking it to Taylor's series interpretation.
  • One participant highlights the differences between the two interpretations by providing an example with f(x) = x^2, showing that the results diverge based on the method used.
  • A later reply connects the discussion to the Mathieu equation, expressing concern about the complexity of using series to solve it.
Participants express differing interpretations of the operator cos(d/dx) and its application, with no consensus reached on a single approach or solution method.
Participants note the complexity of the Mathieu equation and the potential difficulties in applying series methods, but do not resolve the implications of these challenges.
iver
I have a queation as below
[cos(d/dx)]f(x)
How to solve it? I just konw that the angle is an operator, but the function of x is out of the cosine function.
They probably mean
[tex]\cos ({d/dx}) = 1 - \frac{1}{2!}\frac{d^2}{dx^2} + \frac{1}{4!}\frac{d^4}{dx^4} - ...[/tex]
Just as I would interpret f(g)(x) to mean f(g(x)), I would interpret cos(d/dx)f(x) to mean cos(df/dx). That would, I believe, give the same thing as dx's Taylor's series interpretation.
The two suggestions are different. Because the OP says the answer is an operator probably the interpretation of dx is the intended one.
Let's see why they are different. Try the example [tex]f(x) = x^2[/tex] so that [tex]f'(x) = 2x[/tex] and [tex]f''(x) = 2[/tex], and all higher derivatives are zero.
Then under the dx method, we get
[tex] f(x) - \frac{1}{2!}\;f''(x) = x^2 - 1[/tex]
but under the HallsOfIvy method, we get
[tex] \sin(f'(x)) = \sin(2x)[/tex]
Not the same.
Thx~~
But, this term comes from the Mathieu’s equation as below
[tex] \frac{d^{2}f\left(x\right)}{dx^{2}}+\left(\epsilon-\cos\frac{d}{dx}\right)f\left(x\right)=0[/tex]
If I use series, this equation would be so terrible
  • · Replies 17 ·
