Determining Series vs. Parallel Configuration in Two-Capacitor Circuit
  • Thread starter Thread starter jg370
The discussion centers on determining the configuration of two capacitors in a circuit after a switch is closed. It is established that when the switch is closed, the capacitors are connected in parallel, while simultaneously behaving as if they are in series due to the same current flowing through them. The solution involves applying lumped circuit theory and Kirchoff’s Laws to analyze the circuit effectively. Understanding these principles is crucial for accurately calculating potential differences and energy storage in capacitors.
  • Understanding of lumped circuit theory
  • Familiarity with Kirchoff’s Laws
  • Basic knowledge of capacitor behavior in electrical circuits
  • Ability to interpret circuit diagrams
  • Study the application of Kirchoff’s Laws in complex circuits
  • Learn about the characteristics of ideal circuits and their implications
  • Explore the differences between series and parallel capacitor configurations
  • Review potential energy calculations in capacitors
Electrical engineering students, circuit designers, and anyone interested in understanding capacitor configurations and their implications in circuit analysis.
jg370
This is most likely a well known problem. I think that I could deal with its basic aspects such as calculating the magnitude of the potential difference across each capacitor, the potential energy store in the two capacitor after the switch is close, ect, if I could determine whether the two capacitors are connected in series or in parallel once the switch is close.
If I treat the charged capacitor as an emf source, I am led to think that the two capacitors are connected in series. However, if I consider the arrangement as two capacitors, then I see them as paralllel connected.
Can anyone give me an idea how to determine whether the two capacitors are in series or in parallel once the switch is closed.
Refer to the following for a diagram of the circuit.
www.livemath.com/lmstorage/files/1086007595696[/URL]
Thank you for your help,
JG
jg370,
When you close the switch the capacitors are connected in parallel.
Good luck
They are simultaneously in series (same current) and in parallel (same voltage).
The solution to the problem requires that you first recognize that the model likely being used is that of an “ideal” circuit (i.e., lumped circuit theory). In applying lumped circuit theory, we distinguish between the electrical properties (resistance, capacitance, and inductance) and physical circuit elements (resistor, capacitor, and inductor). If you bear that in mind, and then carefully apply Kirchoff’s Laws, you will arrive at the answer. (See the discussion http://www.ilovephysics.com/cgi-bin/index.cgi?action=forum&board=conceptdiscadv&op=display&num=50 ).
-Martin
