Matching Input and Output Current on Transformers: A Common Question
  • Thread starter Thread starter harblargh
    Transformers
The discussion revolves around the relationship between input and output current in transformers, particularly addressing whether the input current must match the rated output current to achieve the specified output. It includes theoretical considerations and practical implications related to transformer efficiency and load conditions.
  • One participant questions whether the input current must match the rated output current to achieve that output.
  • Another participant explains that while the input current does not need to match the output current, the output voltage can depend on the load and the efficiency of the transformer.
  • A participant mentions that for transformers with poor regulation, running below rated load can lead to higher output voltage, which may affect applications depending on voltage tolerance.
  • One participant provides a formula for calculating input current based on output current and turns ratio, using an example of a step-down transformer.
  • Another participant introduces the concept of power, calculating the primary current required for a given output power and voltage, confirming it aligns with previous calculations based on turns ratio.
Participants generally agree on the relationship between input and output current as described by turns ratio and power calculations, but there are nuances regarding transformer regulation and its impact on output voltage that remain open for discussion.
Participants mention assumptions regarding transformer efficiency and regulation, which may affect the accuracy of calculations. The discussion does not resolve these assumptions or their implications fully.
This discussion may be useful for individuals interested in electrical engineering, particularly those studying transformer operation and efficiency in practical applications.
harblargh
Okay, now this may sound ridiculously stupid, but I know next to nothing about transformers and so I have a question:
Does the input current on a transformer have to match the rated output in order to get that output?
(i.e. A trans rated 5 amps putting out the full rated current on only 2.5 amps of input current.)
No, but depending on the regulation (essentially a measure of how efficient the transformer is) the output voltage maybe be dependent upon load--put another way, in order to get the stated output voltage given the correct input voltage, it must be run at or very near the rated load current. For transformers with good regulation, this is less important, but for those with relatively poor regulation, running it at much less than full rated load can result in a significantly higher output voltage. This may or may not be important, depending on the application's tolerance for voltage deviation.
However, to answer the question I think you're asking, the input current will be equal to the output current divided the turns ratio (the voltages will follow the inverse of this). For example, if your transformer has a load of 10 amps on the output and it's a 120-to-12 volt stepdown transformer, the input will be 10 A / (10/1) = 1 A, assuming an ideal transformer.
Oh. Thanks for the help.
The problem I just can't wrap my brain around is the actual flow of current. That's the issue.
For this hypothetical transformer, the rating is 50A with a matching load run though a VFD with a max load of 75V. Ergo, at maximum, the output would have to be 75V@50A.
What amperage would the 100V input would have to be to reach the maximum output rating?
Assuming decent regulation the loaded voltage ratio will roughly approximate the turns ratio (for a much more accurate figure, take the no-load voltage ratio). So, you can plug those figures into the equation in my previous post [input current = output current / (primary turns / secondary turns)] and that will be your answer.
Maybe it would help to look at the power involved.
Assuming a resistive load...
power in load = 75 volts times 50 amps = 3750 watts
The transformer is 100% efficient so...
3750 watts at 100 volts must mean a current in the primary of
(3750 watts / 100 volts) = 37.5 amps
since power = voltage times current.
This is the same answer as you get if you divide the output current by the turns ratio as above.
ie 50 amps /( 100 / 75 ) =37.5 amps.
Ah, I get it now. Thanks a lot, I really appreciate it. :biggrin:
  • · Replies 38 ·
  • · Replies 46 ·
  • · Replies 36 ·
  • · Replies 20 ·
