The measurement of current and voltage
The discussion revolves around the measurement of current and voltage using a voltmeter with two scales. The problem involves determining the coil resistance and full-scale current of a galvanometer, with specific resistances connected in series for each voltage scale.
  • Mixed
  • Participants explore the configuration of the circuits and the equations needed to relate voltage, current, and resistance. There is confusion regarding the setup and the relationship between the unknowns in the equations.
Participants have engaged in deriving equations based on the voltages and resistances, with some suggesting methods to isolate variables. There is recognition that two equations are necessary to solve for the two unknowns, and some have begun to calculate values while questioning the consistency of their results.
There is an emphasis on the need for clarity regarding the circuit configuration and the assumptions about the galvanometer's behavior under different voltage scales. Participants also note the importance of understanding the implications of the measurements and the relationships between the components involved.
runfast220
Two scales on a voltmeter measure voltages up to 20.0 and 30.0V, respectively. The resistance connected in series with the galvanometer is 1680 ohms for the 20.0V scale and 2930 ohms for the 30.0V scale. Determine the coil resistance and the full-scale current of the galvanometer that is used in the voltmeter
V=IR
First I'm confused at is this all in same circuit or in two different ones?
To find Rc I'm pretty sure I need to use the equation: V= I/R+Rc.
I'm not sure how to get this problem started.
It's two separate circuits (usually with a switch to select the range)
Both the circuits have the same unknown resistance = the of the moving coil you are trying to find.
How would I start to find either the current or Resistance of the coil because in the equation I would have both of those as unknowns:
V= I/R+Rc
The current in the coil at full scale is the same on both ranges.
No result yet?
Two unknowns, R and I, so you need two equations.
The voltages in the meter and the series resistor add up to the supplied voltage.
So, you would have one equation like this
30 = ... + ...
and another like this:
20 = ... + ...
One of the ...'s would be the same in both equations, so solving it would be easy.
If you have already done it, I can compare answers (with what I got), for you if you like.
vk6kro said:
No result yet?
30 = ... + ...
20 = ... + ...
I don't understand what your doing with the voltages? I thought I needed to find the current and the resistance of the coil?
OK.
There is a moving coil meter movement which takes a certain amount of current to make it read full scale. There are two resistors that can be put in series with the meter so that it takes 20 volts with one and 30 volts with the other to make the meter read full scale. If the resistors were not there, the meter would read full scale with a much lower voltage across it and you wouldn't be able to measure voltages like 15 volts or 25 volts.
The Formula V = I * R applies for the voltage across the meter movement and also for the voltage across the series resistance.
We need to find two things. The resistance R of the meter movement and the current I it takes to make the meter read full scale. So, we need to get two equations to work out these things.
One thing we know is that if you have two resistors in series, the voltage across both of them equals the sum of the voltages across each of them.
So, if we put 20 volts across the resistor and meter in series, the total must equal 20 volts.
So, you can write the equations like this:
20 volts = Voltage across resistor (I * 1680) + Voltage across meter ( I * R )
30 volts = Voltage across the other resistor ( I * 2930) + Voltage across meter ( I * R )
Now, you want to find I and R. I would probably take the top equation away from the bottom one using only the parts in brackets on the right side.
ok this is what I have so far.
20V= (I*1680)+(I*R)
30V=(I*2930)+(I*R)
(I*R)= 20 - (I*1680)
(I*R)= 30 - (I*2930)
(I*R)=(I*R)
20 - (I*1680)=30 - (I*2930)
I=125
But then when I plug 125 back into the two equations to solve for R, I get different values for R in each equations. Looking at the equations I don't understand how it would be possible for the for the current and resistance to be the same in each equation?
30 - 20 = 2930 I - 1680 I = 1250 I
I = 0.008 amps or 8 mA
The current is the same because the meter is reading full scale in each case and it takes exactly 8 mA to make it read full scale.
Now you need to plug this 0.008 A back into one of the equations and get R.
20= (.008*1680)+(.008*R)
R=820
Thank you for all your help!
Yep, that's right. Well done.
Hope you understood what was going on though.
Can you see that if you have a 20 volt supply and the two resistances (of the resistance and the meter ) add up to 2500 ohms (1680 + 820) then the current will be 8 mA?
And if the supply is 30 volts and the total resistance is 3750 ohms (2930 + 820) then the current will also be 8 mA ?
If you measure 15 volts with the 30 volt meter resistor, the current will be 4 mA and the meter will read half scale.
You may not have come across this before, but it is important stuff to know.
It all makes sense now. Once again thanks for the help.
why is a high voltage 750 miliamps fuse rated as 5 kv and not 250 volts
If the fuse melts, it has to stop the current flowing. So there has to be a big enough gap that there won't be an arc formed and the current continue to flow.
Some fuses put the fuse wire under spring tension so that if the wire melts, the ends where it melted are pulled far apart. This helps to stop arcing.
A 5000 volt rating tells you this fuse could stop 5000 volts. It can also stop 250 volts, of course.
  • · Replies 18 ·
