| Thread Closed |
organic compound molar mass |
Share Thread | Thread Tools |
| Jul8-09, 04:11 PM | #1 |
We did an experiment in lab today where we were given a compound and we had to figure out the chemical formula and molar mass using titration (titrated with NaOH). The compound I got was phthalic acid, and the average molar mass I got was ~135g. This is about 30 grams off of what everyone else in my group got. 2. Relevant equations [(M NaOH)(L NaOH)]/2 = moles of phthalic acid (there were two equivalency points, which is why it had to be divided by 2) moles phthalic acid / mass of sample used = grams of phthalic acid We were then given the mass percents of each element, and I divided these by the atomic masses of each element, then used the ratio of them to figure out the chemical formula, and whether it was a multiple of the ratios used or not (it was: actual formula = C6H4O2) My professor said all of my calculations were correct. 3. The attempt at a solution So my ultimate question is: Why is my molecular mass 30 grams short of everyone else who used phthalic acid? I did the titration 4 times (the 4th time with the TA watching~ an interesting experience), and all 4 times I got between 130 and 137. Any ideas would be great. Thanks!! :) (ps~ this may be the wrong place to post this, but I wasn't sure...) |
| Jul8-09, 08:52 PM | #2 |
If even your professor has verified all your calculations, then perhaps you can blame a contaminated chemical sample @.@
| Jul8-09, 11:15 PM | #3 |
I thought of that too, but the prof said that the samples were all from the same source... good thinking though
| Jul9-09, 03:20 AM | #4 |
Admin
Show details of your work.
Have you used the same titrant others did? |
| Jul13-09, 04:52 PM | #5 |
Which volume of NaOH titratant did you use? The one for the first eq. point or the second?
| Thread Closed |
| Thread Tools | |
Similar Threads for: organic compound molar mass
| mass times avogadro's numbers = molar mass ?? | Biology, Chemistry & Other Homework | 2 | ||
| Organic compound | Biology, Chemistry & Other Homework | 5 | ||
| what is the molar mass of | Introductory Physics Homework | 1 | ||
| PLZ HELP - Molar mass changes at stp?!?! | Introductory Physics Homework | 4 | ||
| molar mass | Chemistry | 7 | ||
