Solidworks COSMOS - How to read results
  • Thread starter Thread starter assafwei
    Cosmos Solidworks
The discussion revolves around interpreting results from COSMOS in SolidWorks, particularly focusing on the Von Mises criterion and its application to stress analysis in materials. Participants explore the relationship between shear and normal stresses, yield strength, and the interpretation of various stress criteria.
  • One participant asserts that the Von Mises criterion is a good approximation for predicting yielding in ductile materials, assuming isotropic conditions.
  • Another participant provides a mathematical expression relating yield stress to principal stresses, indicating that it considers stresses in all directions.
  • There is a question about how to interpret shear and normal stresses, particularly at points of maximum shear, and their correlation to yield strength.
  • Participants discuss the role of shear stress in the Von Mises criterion, with one stating that it is a 'lumped' stress of all principal stresses.
  • Concerns are raised about the usefulness of other stress plots when determining failure or factor of safety, with a focus on the relevance of shear stress limits.
  • A participant acknowledges a misunderstanding after reviewing textbook material, indicating the complexity of the topic.
Participants express differing views on the interpretation of shear and normal stresses in relation to the Von Mises criterion, and there is no consensus on how these stresses interact at maximum shear points. The discussion remains unresolved regarding the best approach to correlate these stresses with yield strength.
Some participants reference specific conditions such as isotropic and orthotropic materials, indicating that the applicability of the Von Mises criterion may depend on material properties. There are also mentions of stress invariants and the limitations of various stress criteria.
assafwei
Hi,
First of all I must say, I am a bit ashamed asking this question...
Since its been a long time since I studied mechanics of materials and since I never used it in my line of work, I am trying to analyze a problem regarding this subject using COSMOS in solidworks, I have a model and I figured out the boundary conditions and the forces acting in the system. The analysis seems ok, but i have difficulties trying to remember what the numbers say...
Assuming small displacements, I am using the VON MISSES criteria, as far as I remember this criteria predicts yielding of ductile materials in a good manner, first of all, is this correct?
Second - how does the other criteria (shear and normal stresses in all directions) should be interpreted, and how can they be correlated to the yield strength?
Thanks.
1. yes von misses is a good approximation assuming isotroptic materials.
2. 2sigy^2 = (sig1-sig2)^2 + (sig2-sig3)^2 + (sig1-sig3)^2
where
sigy = yield stress of isotropic matieral
sig1 = largest principle stress (from your mohrs circle)
sig2 = second principle
sig3 = third principle
principle stress => no shear
sigy = Fy/A
The reason this equation works is because it takes the principle stresses into consideration in all directions.
We kno G = E/2*(1+eta) = only usable on isotropic materials
where eta is poissons ratio, G = shear modulus and E = mod of elasticity.
remember how when you strain somthing it either expans or shrinks in a different direction, von misses takes those aspects into consideration.
I don't know if I did well at answering your question... but what do you mean by "Second - how does the other criteria (shear and normal stresses in all directions) should be interpreted, and how can they be correlated to the yield strength?"
other criteria in the equation? or other stress criterions?
*Von misses stress = maximum distortion energy theory = maximum octahedral shear stress criterion
For orthotropic, and anisotropic materials other stress criterion are used if memory serves me correct? This would exclude composites from von-misses stress prerequisites. For example, E1 does not equal E2 and v12/E1 = v21/E2
Thanks for the reply,
I meant the other stress criterions, Since I know shear is the critical parameter, I check all three shear parameters, but than how should I consider the normal stresses in the points where the shear is at maximum, do they increase or decrease the stresses on the material?
BTW - if von mises only adherds to the stress invariants and not the shear stresses, how is shear taken into account in the von mises criterion?
Von Mises does take into account shear stress. As Nick said its basically a 'lumped' stress of all principle stresses, and generally asumed to ast in the direction of the largest principle stress.
Priniciple stresses are not 'real' per se. Its a combination of he normal and shear acting in a certain direction. (I think this is where you are going wrong, but I guess you already knew it, so sorry if it sounded patronising)
Other stress plots arent really useful if you only want to determine failure or factor of safety, as Von Mises allows you to to directly compare it to the yield or tensile strength.
But the shear plot is useful if you know that a certin shear stress is unacceptable even if the von mises is within acceptable limits. (you wouldn't compare this to yield stress but he shear limit)
The normal stresses are the same as above only can be compared to the yield strength. Both are basically a breakdown of what goes into the calculating the principle stresses.
I returned to the textbook and realized I was really wrong.
Thanks for the replies it really helped.
  • · Replies 20 ·
19K
