Calculating Loads in Two Co-Axial Helical Springs
  • Thread starter Thread starter Alwightmush
    Springs
The discussion focuses on calculating loads in two co-axial helical springs subjected to a compressive force of 450 N. The outer spring has a mean coil diameter of 100 mm, while the inner spring has a mean coil diameter of 75 mm. The correct loads for the outer and inner springs are determined to be 316 N and 134 N, respectively. The participants emphasize the importance of using the shear stress formula and the spring constant formula to derive the correct load distribution between the two springs.
  • Understanding of helical spring mechanics
  • Familiarity with shear stress calculations
  • Knowledge of spring constant formula: k = (G*d^4)/(8*D^3*n)
  • Ability to solve simultaneous equations
  • Study the derivation of the shear stress formula for helical springs
  • Learn how to apply the spring constant formula in practical scenarios
  • Practice solving simultaneous equations in mechanical contexts
  • Explore the effects of varying coil diameters on load distribution in springs
Mechanical engineering students, professionals working with spring design, and anyone involved in structural analysis of co-axial spring systems.
Alwightmush
2. Two helical springs of the same initial length are made from the same circular section wire and have the same number of coils. They are assembled co-axially and are compressed between two parallel plates by a force of 450 N. The mean coil diameters of the outer and inner springs are 100 mm and 75 mm respectively. Determine the load in each spring.
(Answer: 316 N, 134 N)
F = (Τ x Pi x d^3) / (8 x D) ?
3. Own working
I tried using the figures in the above equation to calculate values for the Shear Stress T but wasn't sure how to separate the loads into a part for each spring.
Question as above, answers as well, but I can't figure out how to calculate them as I don't have the correct formula I presume.
Any help would be much appreciated, exam tomorrow looms. :(
how about using the formula for the spring constant (the shear stresses will be different in each spring, so you're adding a variable) ie.
you know that G,d and n are the same for each and you know the ratios of D.
You should then get to something like:
(0.75^3)F1 + F1 = 450N
and F1 + F2 = 450N
solving simulatneously should get you the answers specified.
  • · Replies 48 ·
9K
