Thanks Moe, but i'm afraid that's not what i'm confused about. I don't have much qualms about the the equation for acceleration of the rocket. Perhaps my confusion can be enlightened by an example.
Consider a rocket accelerating from rest in outer space. Beginning with the differential equation mentioned in my first post one can derive the velocity of the rocket at a later time. v_ex is relative speed and dm/dt is negative. m0 is the initial mass of rocket with fuel.
Consider the thrust to be equal to m dv/dt. Then the
impulse is:
On the other hand the
momentum of the rocket has changed as follows:
Unfortunantly the impulse provided by the thrust (as defined by most resources) on the rocket does not appear (at least on the outset) to equal the change in the momentum of the system. If one considers the thrust to not be m dv/dt but the more complete m dv/dt + v dm/dt, then it does appear to work.
Which does appear to equal the change in momentum of the rocket. I'm not saying that this is neccesarily correct, but so far it makes more sense, especially since the impulse of the thrust on the rocket should give it's change in momentum.
