Pjpic
- 235
- 1
Does the fact that things move mean that there exists something called emptiness for which them to move into?
The discussion revolves around the concept of motion in a hypothetical medium with Planck density, questioning whether motion requires the existence of empty space. Participants explore thought experiments and philosophical implications regarding the nature of space and motion, touching on theoretical scenarios and the implications of physical laws.
Participants do not reach a consensus on whether motion can occur without empty space. Multiple competing views remain, with some arguing for the necessity of voids for initiating motion, while others maintain that motion can be sustained in a filled medium.
Participants acknowledge the limitations of their thought experiments, including the assumptions made about the nature of matter and the physical laws that govern motion. The discussion highlights the complexities of defining motion in a universe with varying densities and the implications of theoretical constructs.
This discussion may be of interest to those exploring theoretical physics, philosophy of space and motion, and the implications of physical laws in hypothetical scenarios.
Pjpic said:Does the fact that things move mean that there exists something called emptiness for which them to move into?
AUMathTutor said:Pjpic:
Not necessarily. Imagine an empty universe where all our laws of physics still hold. Now imagine filling all of it uniformly with matter. Now imagine hollowing out a sphere the size of a basketball. Now put the basketball inside, and start it spinning (imagine there is no friction... or even if there is, so what?) There is no empty space in the universe (the technicalities of there being void inside an atom can be overcome if necessary or better left ignored) and the basketball is spinning. No laws of physics are violated, so sure, why not.
Another experiment: fill a bucket with water. Put a small piece of wood inside. Close the bucket so that it is airtight and there is no air left in the bucket. Shake the bucket. The wood will move.
How would you spin the ball without applying some sort of pressure. And wouldn't that mean an area of lower pressure (where there's is more empty space) is needed to push against?
Not in a real world. This would require infinitely dense objects made up of infinitely small particles, zero friction, zero viscosity. If the particles were tiny cubes with no gaps, then the movment between particles would be restricted to parallel to the surfaces of the cubes. I'm not sure if this would allow a solid to flow through a fluid. Also if the cubes were incompressable, then the speed of sound (or information of movement) is infinite.AUMathTutor said:Clearly, motion can be sustained in the absence of empty space.
Not necessarily. Imagine an empty universe where all our laws of physics still hold. Now imagine filling all of it uniformly with matter. Now imagine hollowing out a sphere the size of a basketball. ..
gmax137 said:...by "hollowing out a sphere" do you mean "replace the matter with emptiness"?
AUMathTutor said:"by "hollowing out a sphere" do you mean "replace the matter with emptiness"? Once you have "hollowed out" this void, how do you get your basketball through the surrounding matter to enter that void?"
Yes, just carve out a sphere...
Is it possible you are missing his point?gmax137 said:Do you see that you are requiring an empty place to place your ball, and then go on to conclude you don't need empty space to move an object into? Your thought experiment is inconsistent, or ironic, or something. It doesn't hold up to scrutiny; it seems to ignore the issue it professes to explain.
DaveC426913 said:Is it possible you are missing his point?
