Electron, point charge, and surface charge
The discussion centers on determining the position of an electron in the presence of a point charge and a uniform surface charge density. The point charge, q=10^{-9}, is located at (0,0,1), while the surface charge density, ρ_s=10^{-9}, is on the z=0 plane. The solution involves balancing the electric fields from both the point charge and the surface charge, leading to the conclusion that the electron can be placed at m=0.6011 on the z-axis for it to remain stationary.
  • Understanding of electric fields and forces, specifically the equations for point charges and surface charge densities.
  • Familiarity with the concept of electric field symmetry, particularly in relation to planar charge distributions.
  • Knowledge of the equation for electric field due to a surface charge, \(\mathbf{E}_{\rho_s}=\frac{\rho_s}{2\varepsilon_0}\).
  • Ability to solve equations involving electric fields and forces, particularly in three-dimensional space.
  • Study the derivation of electric fields from point charges using Coulomb's law.
  • Learn about the behavior of induced charges on conductors in electrostatic equilibrium.
  • Explore the concept of superposition of electric fields from multiple charge distributions.
  • Investigate the implications of charge density on the electric field in various geometries.
This discussion is beneficial for physics students, particularly those studying electromagnetism, as well as educators and anyone interested in understanding the interactions between point charges and surface charge densities in electrostatics.
makhoma
The [itex]z=0[/itex] plane is covered with the uniform surface charge density, [itex]\rho_s=10^{-9}[/itex], while at the same time the point charge [itex]q=10^{-9}[/itex] is located at (0,0,1). Where can an electron be place so if released, it will not move.
[itex]\mathbf{E}(\mathbf{r})=\frac{1}{4\pi\varepsilon_0}\sum_{n=1}^N\frac{q_n(\mathbf{r}-\mathbf{r}_n)}{\left|\mathbf{r}-\mathbf{r}_n\right|^3}[/itex]
[itex]\mathbf{F}=q\mathbf{E}[/itex]
I assume that the forces will net to zero,
[itex]\mathbf{F}=e\mathbf{E}_{\rho_s}+e\mathbf{E}_q=0[/itex]
[itex]\therefore\mathbf{E}_{\rho_s}=-\mathbf{E}_q[/itex]
I know that, due to symmetry, the surface charge only acts in the z-direction. Since the point charge is given to be at (0,0,1), I expect the solution to be of the form (0,0,m). I tried using the electric field of the surface charge to be
[itex]\mathbf{E}_{\rho_s}=\frac{\rho_s}{2\varepsilon_0}[/itex]
but I am not sure that that is acceptable since there is a charge in this problem and that answer is for just the plane alone.
Not sure where to start really, other than the force equations, but after that I'm stuck as to how to go about solving this problem, any and all help is appreciated!
Is the plane a conductor? Will the point charge induce some charge density on the plane?
If not, why wouldn't the field due to the plane just be [itex]\mathbf{E}_{\rho_s}=\frac{\rho_s}{2\varepsilon_0}\hat{z}[/itex]?
Well, you've already posted the field of the plane...what's the field of the point charge [itex]\textbf{E}_q[/itex]? Where does [itex]\textbf{E}_{\rho_s}=-\textbf{E}_{q}[/itex]?
The electric field of the point charge is
[itex]\mathbf{E}=\frac{1}{4\pi\varepsilon_0}\cdot\frac{q(0\mathbf{x}+0\mathbf{y}+(1-m)\mathbf{z})}{\left((0)^2+(0)^2+(1-m)^2\right)^\frac{3}{2}}[/itex]
where I put the reference point at a position m, between 0 and 1 on the z-axis.
This makes the force equation
[itex] \frac{\rho_s}{2\varepsilon_0}=-\frac{1}{4\pi\varepsilon_0}\cdot\frac{q}{(1-m)^2}[/itex]
Solving this for m,
[itex] m=1-\sqrt{ \frac{2\varepsilon_0}{4\pi\varepsilon_0}\cdot\frac{q}{\rho_s}}[/itex]
This gets me m=0.6011, which I am told is the answer. Thanks for your help! I think my problem was that I was over complicating the problem by assuming that the point charge would have an effect on the surface charge (and vice versa). I'll have to remember these things as I head into grad school this year!
