In order for the square of a matrix to be equal to the matrix
  • Thread starter Thread starter megalomaniac
    Matrix Square
The discussion revolves around the properties of idempotent matrices, specifically those matrices A for which A² = A. Participants explore the implications of this property, including conditions under which A is singular or equal to the identity matrix.
  • Participants discuss the necessity for A to be a square matrix and question the implications of singularity on the idempotent property. Various attempts to prove that non-identity idempotent matrices must be singular are presented, alongside counter-examples and hints about diagonal matrices.
The discussion is active, with participants providing hints and counter-examples. Some have proposed that the only non-singular idempotent matrix is the identity matrix, while others are exploring the relationship between singular matrices and idempotency. There is a recognition of the need to clarify the properties of diagonal idempotent matrices and their singular counterparts.
Participants are navigating the complexities of matrix properties under the constraints of homework rules, focusing on proving relationships without providing complete solutions. The discussion includes considerations of eigenvalues and similarity transformations, with some participants expressing uncertainty about their understanding of these concepts.
megalomaniac
Idempotent Matrix Proof
Given a matrix A where A2 = A, find the properties of A.
detA = ai1ci1 + ai2ci2 + ... + aincin (where cij = (-1)i+j*detAij)
aij = ai1a1j + ai2a2j + ... + ainanj
In order for A2 to be defined, A must be a square matrix.
I have concluded that A must either equal the identity matrix I, or A must be singular.
I am having trouble proving this in the general case.
Hint: If A is not singular, it has an inverse. Use this fact.
Well I found a counter-example that disproves that A is singular. The matrix {{1, 2, 3}, {4, 5, 6}, {7, 8, 9}} is a singular matrix that does not satisfy A2 = A.
So A must equal I. So AA-1 = I. But I still need a good way to prove this, and proofs are my deficiency.
No, all you have done is to prove that singularity does not guarantee that A2=A.
Hint: The zero matrix is singular.
Ok, now I'm just having problems determining the general properties of singular matrices that would make A2 = A
Thus far I have shown,
Suppose A is an idempotent nxn matrix.
In the case of a non-singular matrix, in order to be invertible, there exists an nxn matrix B such that AB = BA = In, where B = A-1
Since A = B and B = A-1, then A = A-1
AA = In
Therefore In is idempotent.
Would this show that if A = I, then A is idempotent?
Also, now how would I go about showing the only other way for A to be idempotent would be if A is singular, since not all singular matrices are idempotent?
--Thank you.
megalomaniac said:
Since A = B
That was a big leap. You need to show this.
Isn't it kind of obvious that the identity matrix is idempotent?
Trivially, yes. What you have not done is to show that the nxn identity matrix is the only nonsingular nxn idempotent matrix.
Yet another hint: An interesting subset of the idempotent matrices are the diagonal idempotent matrices. What can you say about the diagonal elements?
Isn't the only diagonal idempotent matrix the identity matrix?
Yes, but you have not yet shown this (yet).
There are also singular diagonal idempotent matrices. You might want to think about these for a bit, and whether they have any similarity to non-diagonal idempotent matrices.
If A is idempotent and non-singular:
If I premultiply both sides by A-1, then I get:
A = InA = A-1AA = A-1A = In.
Would this be valid?
As for the diagonal idempotent matrices, they have full rank and therefore are non-singular and symmetric and non-diagonal idempotent matrices would be singular.
EDIT: And each entry of a diagonal idempotent matrix would have to be 0 or 1.
Finally.
[tex]\bmatrix 1 & 0 \\ 0 & 0\endbmatrix[/tex]
This matrix is diagonal, is idempotent, and is not full rank.
Better.
So for all diagonal idempotent matrices, A2 = A iff ai2 = ai for all i=1,...,n. This can only occur for i values of 0 and 1. Therefore, a diagonal matrix is idempotent iff each diagonal entry is 0 or 1.
So any idempotent diagonal matrix will be singular (save for I), but this still doesn't encompass all singular idempotent matrices.
I appreciate your help!
You're welcome.
Regarding the non-diagonal idempotent matrices. I dropped a BIG clue in post #9. You haven't picked up on it yet. Reread the post. Ponder over each word.
So far it seems that the sum of the diagonal entries of an idempotent singular matrix must equal one, and the rows and/or columns must be linearly dependent.
Ok, I have determined that detA equals the product of the eigenvalues. So in order for A to be singular, at least one eigenvalue must be zero. Where would I go from here to prove a singular idempotent matrix must have at least one zero eigenvalue?
-Thanks!
You don't need to do that. Any singular matrix has at least one zero eigenvalue.
The key word in post #9 was similarity. Forget eigenvalues. Think similarity.
So am I to show that a singular diagonal idempotent matrix is similar to a singular non-diagonal idempotent matrix? I'm sorry, I'm still unsure on how to go about this, my mind's been all over the place.
Try the other way around first. You already know that a diagonal matrix whose diagonal elements are either zero or one is idempotent. Show that an arbitrary similarity transform yields another idempotent matrix.
I haven't spent too much time dealing with similar matrices, but I'm assuming I am to use the fact that if B=P-1AP for some invertible matrix P, then A is similar to B. And A would be an idempotent diagonal matrix in this case?
Yes. So what is B2 if B=P-1AP and A2=A?
So B2=(P-1)2A2P2 = AI = A?
No. Matrix math doesn't work that way. Try again.
Ha oops,
How about: P-1APP-1AP = P-1AIAP = P-1AAP = P-1AP. So B2 = B ?
There you go.
But how does that prove that A must be singular?
It doesn't. It shows that a matrix that is similar to an idempotent matrix is idempotent.
But I'm trying to prove that if an idempotent matrix is not the identity matrix, then it must be singular. How do I make this leap?
-Thank you!
Obvious point: the identity matrix satisfies I2= I but is not singular.
A2= A is equivalent to A2- A= A(A-I)= 0. It does NOT follow that "A= 0 or A= I" but it does follow that either A or A- I has determinant 0.
Oh wow! I never looked at it that way! How does it follow that A has determinant 0?
-Thanks!
I was thinking, since I've proven the only non-singular idempotent matrix is the identity matrix, wouldn't it follow that the only other idempotent matrices must be singular?
  • · Replies 25 ·
  • · Replies 18 ·
  • · Replies 69 ·
11K
  • · Replies 23 ·
  • · Replies 33 ·
