Approximating Non Linear Systems by Using The Matrix Eponential
  • Context: Graduate
  • Thread starter Thread starter John Creighto
    Linear Matrix Systems
This discussion focuses on approximating non-linear systems using matrix exponentials, specifically through the transformation of first-order ordinary differential equations (ODEs) into second-order and higher-order systems. The author demonstrates how to derive a linear approximation of the non-linear ODE \(\dot{x_1} = a x_1^2\) and discusses the advantages of this method, including larger step sizes and improved error propagation. Key techniques such as scaling and squaring for computing matrix exponentials are emphasized, along with potential pitfalls like numerical instability in high-order systems.
  • Understanding of ordinary differential equations (ODEs)
  • Familiarity with matrix exponentials and their properties
  • Knowledge of numerical methods for solving differential equations
  • Experience with error analysis in numerical computations
  • Research "Matrix Exponential Scaling and Squaring" techniques
  • Study "Higher-Order ODE Approximations" in numerical analysis
  • Explore "Error Propagation in Numerical Methods" for differential equations
  • Learn about "Pade Approximation" and its applications in matrix computations
Mathematicians, engineers, and researchers working with non-linear systems, particularly those involved in numerical analysis and computational modeling of differential equations.
John Creighto
I tried posting this to my blog but the preview function wasn't rendering the formula's correctly and once I posted it I couldn't edit it.
https://www.physicsforums.com/blog.php?b=1152
Therefor I'll post it here instead.
For simplicity let's consider a very simple ODE.
\dot{x_1}=a x_1^2
We can approximate this first order system with a second order ODE as follows:
<br /> \left[ \begin{array}{c}<br /> \dot{x_1} \\<br /> \dot{x_2} \end{array} \right]<br /> =<br /> \left[ \begin{array}{ccc}<br /> 0 &amp; 1 \\<br /> 0 &amp; <br /> \frac{d f(x_1)}{d x_1}<br /> \end{array} \right]<br /> <br /> \left[ \begin{array}{c}<br /> x_1 \\<br /> x_2 \end{array} \right]<br />
Where
<br /> x_2=\frac{dx_1}{dt}<br />
Or in the simple case mentioned above we have:
<br /> \left[ \begin{array}{c}<br /> \dot{x_1} \\<br /> \dot{x_2} \end{array} \right]<br /> =<br /> \left[ \begin{array}{ccc}<br /> 0 &amp; 1 \\<br /> 0 &amp; 2x_1(t_o) \end{array} \right]<br /> <br /> \left[ \begin{array}{c}<br /> x_1 \\<br /> x_2 \end{array} \right]<br />
Using the matrix exponential the solution to the linear approximation of this stem as follows:
<br /> \left[ \begin{array}{c}<br /> x(t) \\<br /> \dot{x}(t) \end{array} \right]<br /> =<br /> exp \left( \left[ \begin{array}{ccc}<br /> 0 &amp; 1 \\<br /> 0 &amp; <br /> 2x_1(t_o) \end{array} \right] (t-t_o) \right)<br /> <br /> \left[ \begin{array}{c}<br /> x(t_o)) \\<br /> \dot{x}(t_o) \end{array} \right]<br />
Where:
\dot{x}(t_o)=ax(t_o)^2
Keep in mind the choice of using a second order approximation was somewhat arbitrary. We could of equally well, done a third order approximation as follows:
<br /> \left[ \begin{array}{c}<br /> \dot{x_1} \\<br /> \dot{x_2} \\<br /> \dot{x_3} \end{array} \right]<br /> =<br /> \left[ \begin{array}{ccc}<br /> 0 &amp; 1 &amp; 0\\<br /> 0 &amp; 0 &amp; 1\\<br /> 0 &amp; 2 a &amp; 2 a x(t_o)<br /> \end{array} \right]<br /> <br /> \left[ \begin{array}{c}<br /> x_1 \\<br /> x_2 \\<br /> x_3 \end{array} \right]<br />
Where
<br /> x_2=\frac{dx_1}{dt}, x_3=\frac{d^2x_1}{dt^2} <br /> <br />
and
\ddot{x}(t_o)=2 a x(t_o) \dot{x}(t_o)=2a^2x(t_o)^3Which can also be solved using the matrix exponential.
In the last post it was shown how to approximate a non linear system with a linear system of arbitrary order. This has several advantages over standard ODE numeric algorithms.
1) There is the potential to take larger step sizes.
2) It is useful in estimation problems because we can derive linear relationships between the current state and the future value.
3) We can develop expressions for error propagation
4) It allows if desired the separation of fast and slow dynamics (note that this is also done in ODE solvers for stiff systems)
5) Error propagation can be reduced by the use of scaling and squaring.
As for possible disadvantages:
1) The computation of the matrix exponential could be complex for high order systems.
2) Numerical problems could arise if there are high order poles or poles which are close together.
3) Some linearities may not be approximated well with linear systems.
Now, well the algorithm allows for the potential of large step sizes this is more a matter of efficiency then numerical accuracy unless the matrix exponential is computed by using matrix denationalization. Matrix diagonalization only tends to be more accurate if the state space matrix is near symmetric (loosely coupled systems). Otherwise scaling and squaring algorithms tend to be more reliable in computing the matrix exponential.
The scaling and squaring principle works on the premises that:
exp(A)=exp(A/s)^s
Where A is a matrix and s is a constant.
(note that it is easy to show that is in gneral doesn't work if s is a matrix unless A and S commute.)
A is scaled by s to be sufficiently small so that exp(A/s) can be approximated with a pade approximation. The squaring is done recursively. That is:
A^n=A^{n/2}A^{n/2}
This reduces numerical error and the number of multiplications.
The choice of s is critical because if s is too large then there will be too much error introduced by the pade approximation but if s is too small then there will be too much error introduced by the squaring part of the algorithm.
It should be noted that when solving the differential equation we are computing the matrix exponential of At. If s is our scaling factor then as long as the time step is not less then t/s we will not introduce any additional error by taking intermediate steps. Therefor if our only concern is accuracy we should compute the matrix exponential of At/s for each time step.
If we were naive then we could now solve the differential equation as follows:
\boldsymbol{x}(t+t/s)=exp(A(t)t/s)\boldsymbol{x}(t)
This has the advantage over taking large time steps in that we can recompute the matrix exponential each time step but the disadvantage that it requires n multiplication for n step. This could result in large error propagation.
Well, we may need to do this to initially compute our state space matrix for the next time step once we have initialized the state space matrices we can reculculate the value of the the states based on large time steps using the following recursive relationship.
exp(A(t_1,t_2))=exp \left( A \left( t_1,\frac{t_2+t_1}{2} \right) \right) exp \left( A \left( \frac{t_2+t_1}{2},t_1 \right) \right)
Where the recursion is terminated when t_2-t_1 is sufficiently small that we can approximate an average state transition matrix over the interval [t_2,t_1]. Example approximations include:
exp(A(t_1,t_2)) \approx exp(A(t_1)(t_2-t_1))
exp(A(t_1,t_2)) \approx exp \left( \frac{A(t_1)+A(t_2)}{2} (t_2-t_1) \right) \right)
We expect good numerical accuracy if we can make the above approximation when t_2-t_1 is above or at least not a lot smaller then the chosen scale factor s.
Intuitively this scaling and squaring should improve numerical accuracy as additions and subtractions will take place with respect to numbers that will likely be more simmilar in magnitude. (I'll see if I can find a proof).
In my firt Post we considered second order approximations: <br /> <br /> \left[ \begin{array}{c}<br /> \dot{x_1} \\<br /> \dot{x_2} \end{array} \right]<br /> =<br /> \left[ \begin{array}{ccc}<br /> 0 &amp; 1 \\<br /> 0 &amp; <br /> \frac{d f(x_1)}{d x_1}<br /> \end{array} \right]<br /> <br /> \left[ \begin{array}{c}<br /> x_1 \\<br /> x_2 \end{array} \right]<br /> <br />
of the system:
<br /> \dot{x_1}=a x_1^2<br />
Giving the linear approximation:
<br /> <br /> \left[ \begin{array}{c}<br /> \dot{x_1} \\<br /> \dot{x_2} \end{array} \right]<br /> =<br /> \left[ \begin{array}{ccc}<br /> 0 &amp; 1 \\<br /> 0 &amp; 2x_1(t_o) \end{array} \right]<br /> <br /> \left[ \begin{array}{c}<br /> x_1 \\<br /> x_2 \end{array} \right]<br /> <br />
In this approximation we:
- Derive an expression for \ddot{x} from the first order differential equation.
-The \ddot{x} is approximated as a linear function of the first derivative.
-The x is computed as the integral of \dot{x}.
Because the resulting differential exultation computes x purely as an integral of \dot{x}, the computation is metastable. This could unnecessarily increase error propagation. To correct this we should feed back information about x into the computation of \ddot{x}.
The error in our computation of \ddot{x} is given by:
e(\ddot{x})=\left(\frac{df(x)}{dx}-\frac{df(x(t_o))}{dx}\right)(\dot{x}-\dot{x}_)
Or in our example:
e(\ddot{x})=2\left(x-x_o\right)(\dot{x}-\dot{x}_o)
e(\ddot{x})=2\left(x-x_o\right)(x^2-\dot{x}_o)
e(\ddot{x})=2(x^3-x\dot{x}_o-x_ox^2+\dot{x}_ox_o)
differentiating with respect to x:
\dot{e}(\ddot{x})=2(3x^2-\dot{x}_o-2x_ox)
\dot{e}(\ddot{x})=4x_o^2-4x_o^3
<br /> <br /> \left[ \begin{array}{c}<br /> \dot{x_1} \\<br /> \dot{x_2} \end{array} \right]<br /> =<br /> \left[ \begin{array}{ccc}<br /> 0 &amp; 1 \\<br /> (4x_o^2-4x_o^3) &amp; 2x_1(t_o) \end{array} \right]<br /> <br /> \left[ \begin{array}{c}<br /> x_1 \\<br /> x_2 \end{array} \right]<br /> +<br /> \left[ \begin{array}{c}<br /> 0 \\<br /> -(4x_o^2-4x_o^3)x_o \end{array} \right]<br /> <br />
