Question about Lipschitz continuity
The discussion centers on proving that if \( f: X \rightarrow X \) is locally Lipschitz continuous on a normed linear space \( X \) and \( K \) is a compact set, then there exists an open set \( U \) containing \( K \) where \( f \) is Lipschitz continuous. The approach involves taking an open cover of \( K \) with sets where \( f \) is Lipschitz, extracting a finite subcover, and ensuring the resulting open set is convex. The solution confirms that replacing \( K \) with its convex hull maintains compactness, allowing for the construction of an appropriate open set.
  • Understanding of normed linear spaces
  • Knowledge of Lipschitz continuity and its implications
  • Familiarity with compact sets and their properties
  • Experience with open covers and finite subcovers in topology
  • Study the properties of Lipschitz continuous functions in normed spaces
  • Learn about the concept of convex hulls and their relevance in analysis
  • Explore the application of compactness in functional analysis
  • Investigate the relationship between local and global continuity in mathematical functions
Mathematics students, particularly those studying real analysis or functional analysis, as well as educators looking for examples of Lipschitz continuity and compactness in normed spaces.
quasar987
This should be easy but I'm stomped.
Let K be a compact set in a normed linear space X and let f:X-->X be locally Lipschitz continuous on X. Show that there is an open set U containing K on which f is Lipschitz continuous.
locally Lipschitz means that for every x in X, there is a nbdh around x on which f is Lipschitz.
The obvious thing to do it seems it take an open cover of K by sets on which f is Lipschitz continuous and extract a finite subcover. But then what?!?
Wouldn't it be nice if you could make sure that the final open set containing K and covered by the subcover, were convex? Replace K by it's convex hull, it's still compact, right? Then take the finite subcover. Then pick a open set just a 'little' bigger than K, but still convex and contained in the subcover. That works, doesn't it?
Of course, yes! Thanks Dick.
  • · Replies 0 ·
