Explain what this tells you about parametric and symmetric equations in R^3?
The discussion revolves around understanding parametric and symmetric equations in three-dimensional space (R^3), particularly in the context of lines that are parallel to the xy-plane and perpendicular to the z-axis. Participants are exploring the implications of these geometric relationships on the equations representing such lines.
  • Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants are attempting to clarify the relationship between the directional vector of a line and its components in parametric and symmetric forms. Questions arise regarding the implications of being perpendicular to the z-axis and the nature of the z-component in this context.
Some participants have provided insights into the nature of the z-component for lines parallel to the xy-plane, suggesting that it must be zero. Others are seeking further clarification on the transition from parametric to symmetric equations, particularly when the z-component is constant.
There is an emphasis on understanding the definitions and relationships between different types of equations in R^3, with participants expressing confusion about the implications of these geometric properties. The discussion is framed within the constraints of a homework assignment, which may limit the depth of exploration.
axxon
parametric and symmetric equations in R^3??
Recall that there are three coordinates planes in 3-space. A line in R3 is parallel to xy-plane, but not to any of the axes. Explain what this tells you about parametric and symmetric equations in R3. Support your answer using examples.
This question had me thinking for a while, but i want to confirm my understanding or if i am even correct.
I think the line is perpendicular to the Z-axis, So does this mean that the directional vector for z component is 0? basically [ax,ay,0].But couldn't it be perpendicular to xy plane, and still have a directional z component?
But besides that, using that information, in terms of parametric equation it tells us that
the z is just going to equal the position vectors z component.
Now here is where i get confused...with the symmetric equation.
Can you guys please explains this to me in simplest terms...i am trying really hard to understand this vectors in 3 space stuff.
To answer your first questions, yes, it's perpendicular to the Z-axis and there can be no value for the Z component other then 0, otherwise it wouldn't be perpendicular to your xy-plane. If it were perpendicular to the xy-plane, then by definition it would have a Z-component. However, the question is talking about being parallel to the xy-plane.
Ah alrite i just got that i decided to draw out a graph...yes what you said sums that up...now onto the parametric and symmetric equations
can someone please help with the other problem?
well can you answer the second part? am i atleast close?
Given x, y, z as parametric equations with parameter t, you can find the "symmetric" equations by solving each equation for t and setting them all equal. In this case, z is a constant: there is no t so you can't solve for t. The symmetric equations are an equation in x and y with the additional equation "z= constant".
So Symmetric would look like:
[tex]\frac{x-ax}{bx}[/tex]= [tex]\frac{y-ay}{by}[/tex]= az
(where 'az' is a constant)
21K
