Is the sequence finite for different values of u in the logarithmic series?
  • Context: Graduate
  • Thread starter Thread starter zetafunction
    Sequence Variables
The sequence defined by the expression ∑_{n=1}^{∞} (log^{u-1}(n)/n) - u^{-1}log^{u}(n) is analyzed for various values of u. When u=1, the result corresponds to the Euler-Mascheroni constant. For other values of u, the sequence's behavior is less clear and requires further investigation, particularly through the limit lim_{x→∞} - (log x)^{u} + ∑_{n=1}^{x} (log n)^{u-1}/n and the integral ∫_{1}^{∞} (log^{u-1}(x)/x). The discussion emphasizes the need for clarity in the formulation of the sequence to derive meaningful conclusions.
  • Understanding of logarithmic functions and their properties
  • Familiarity with infinite series and convergence
  • Knowledge of the Euler-Mascheroni constant
  • Basic calculus, particularly integration techniques
  • Explore the convergence criteria for logarithmic series
  • Investigate the properties of the Euler-Mascheroni constant in depth
  • Learn about advanced techniques in evaluating limits involving logarithmic functions
  • Study integral calculus related to improper integrals and their applications
Mathematicians, students studying advanced calculus, and researchers interested in series convergence and logarithmic functions will benefit from this discussion.
zetafunction
is the following sequence finite
[tex]\sum_{n=1}^{\infty} \frac{log^{u-1} (n)}{n} - u^{-1}log^{u}(n)[/tex]
if u=1 then we have simply the Euler-Mascheroni constant but what happens in other cases or other values for 'u'
I'm going to go out on a limb and guess that when you write
you mean something like
[tex]\lim_{x\to\infty}-(\log x)^u+\sum_{n=1}^x\frac{(\log n)^{u-1}}{n}[/tex]
but you may mean something else entirely.
no but thanks by the answer i meant
[tex]\sum_{n=1}^{\infty} \frac{log^{u-1}(n)}{n} - \int_{1}^{\infty}\frac{log^{u-1}(x)}{x}[/tex]
in case u=1 we have the Euler Mascheroni constant but how about for other values ??
