Charge Density (Relaxation Time)
The discussion revolves around the concept of charge density in a conductor and its behavior over time, specifically focusing on the equation for the volume charge density's exponential decay. Participants explore the implications of this equation and the conditions under which it applies.
  • Conceptual clarification, Assumption checking, Exploratory
  • Participants question the definition and application of the exponential function describing charge density decay. There is discussion about the initial conditions and constants involved in the equation. Some express confusion about the physical interpretation of the charge density decrease and its relation to different media.
The conversation is ongoing, with multiple interpretations being explored. Some participants provide clarifications regarding the mathematical formulation, while others seek to understand the physical context of the problem. There is no explicit consensus, but guidance on the mathematical aspects has been offered.
Participants are considering the scenario of charge density in a conductor and its interaction with surrounding media, raising questions about the assumptions made in the original problem statement. The discussion includes considerations of how the charge density evolves when materials are introduced into different environments.
jeff1evesque
Statement:
If a volume charge distribution existed inside a conductor at t = 0, the charges would quickly migrate to the outside surfaces due to repulsion. The rate at which the charge density would decrease is given by:
[tex]\rho_{v}(t) = \rho_{v}(t = 0)e^{-\frac{t}{t_{r}}}[/tex] where the relaxation time, [tex]t_{r}[/tex], is [tex]t_{r} = \frac{\epsilon}{\sigma}[/tex].
Question:
But to me, it seems [tex]\rho_{v}(t) = \rho_{v}(t = 0)e^{-\frac{t}{t_{r}}}[/tex] is a function that is not defined. Where is the equation that makes the charge density decrease? Both sides of the equality (above) is a function that is not defined. I feel like this equation is like saying take the equation [tex]F(y) = F(y = a)[/tex] and solve for the function F(y = a, where a could be any of the Real's), which hasn't been defined. Does anyone know how to find the (decreasing) rate of charge density from the equation given? Or even the time it takes for a particular charge density to decrease to some fixed amount say 44coulombs/m^2?
Thanks,
JL
The function is defined. It is an exponential function. rho at t = 0 is a number. More specifically, it is the starting density. This is what normalizes the exponential function. If you plug in t = 0 to the equation, the exponential factor becomes one and you're left with the starting value.
To the find the time it takes to decrease to "x" C/m^2, you set rho equal to x and solve for t.
Why isn't the equation written as, [tex] \rho_{v}(t) = e^{-\frac{t}{t_{r}}}?[/tex]
And to solve for the time it takes to decrease to "x" C/m^2,
[tex] x = e^{-\frac{t}{t_{r}}}?[/tex]
Thanks,
JL
This would be fine if the density was 1 C/m^2 at the start. But if the density is "A" to start, then we must write:
[tex] \rho_{v}(t) = Ae^{-\frac{t}{t_{r}}}[/tex]
We need some kind of constant there. Clearly:
[tex] \rho_{v}(0) = A[/tex]
And to solve for the time it takes to decrease to "x" C/m^2,the equation would be [tex] x = e^{-\frac{t}{t_{r}}}?[/tex]
This decrease of charge density is the decrease of the material inserted into another medium? Or the medium (environment), that decreases in charge density (I'm guessing the former). What if the material (whatever one chooses) is inserted into some other medium (water, pond, big bowl of cool aid, or whatever) at time t = 0. Would 0 be substituted to the equation above for the variable t?
Thanks again.
No. I mean, to find out when rho is equal to x, you'd...set rho equal to x, where rho is defined the way it is in your book and in my last post.
Thanks again.
Sorry, not quite getting your question. The charge in the conductor spreads out due to electrical repulsion, and hence it becomes less dense. I don't think this would change if you immersed the conductor in anything else.
So it would be written like,
[tex] x(t) = Ae^{-\frac{t}{t_{r}}}<br /> [/tex]
And I was wondering what is meant by "The rate at which the charge density would decrease"? Since the equation invovles putting some substance say hot water into a larger medium (cold water). The charge density would mean the hot water decreasing in charge density (not the cold water), correct?
And back to the equation above, if the hot water is inserted into cold water at time t = 0, then 0 would be substituted into the the variable t of the equation:
[tex] x(t) = Ae^{-\frac{t}{t_{r}}} = A.<br /> [/tex]
Interesting point. This may be bad wording on their part. Rho of t is the charge density as a function of time. I would interpret the rate of decrease of the charge density to be the derivative of that function. Oh well. Just words, really.
It does?
I dunno. I don't really have any context here.
I think we might have a communication problem. I feel like you are asking me, "at t = 0, should I set t equal to zero?" If that's not what you meant, can you clarify?
It sounds like the function is meant to tell you how the density evolves with time starting from the "dumping time", which is taken to be t = 0. So, I guess the answer to your question is, yes.
9K
  • · Replies 26 ·
