How Do You Calculate Initial Concentrations in a Rate Law Lab?
  • Thread starter Thread starter PrincessJee
    Initial
The discussion focuses on calculating initial concentrations in a rate law lab involving a 0.020M Br2 solution, 4.0M acetone, and 1.0M HCl, all diluted to a final volume of 25.0mL. The correct method to determine the final concentration (Mf) after dilution is outlined using the equation MiVi = MfVf. Specifically, for 5.0mL of 0.020M Br2, the final concentration is calculated to be 0.0040M, correcting the initial misconception that it would be 4.0M. The importance of understanding dilution principles is emphasized, as diluting a solution decreases its concentration.
  • Understanding of molarity (M) and its calculation.
  • Familiarity with the dilution equation MiVi = MfVf.
  • Basic knowledge of solution preparation and concentration concepts.
  • Ability to perform unit conversions (mL to L).
  • Study the principles of solution dilution and concentration calculations.
  • Learn about the impact of dilution on reaction rates in chemical kinetics.
  • Explore advanced topics in rate laws and their applications in reaction mechanisms.
  • Investigate the use of spectrophotometry for measuring concentrations in chemical solutions.
Chemistry students, laboratory technicians, and educators involved in teaching or learning about chemical kinetics and solution preparation.
PrincessJee
I am trying to calculate the initial concentrations in a rate law lab
If I have the following
0.020M Br2 solution, and am using 5.0mL of it
4.0M acetone, and am using 5.0ml of it
1.0M HCl and am using 5.0ml of it
H2O 10.0ml
how do I calculate the initial concentrations of solutions used in each run (this example is the first run only).
After mixing all the reagents the total volume is 25.0mL, and the concentrations need to be calculate according to this volume?
n=m/M
M=mol/L
this is what I am guessing... but not sure if it is correct...
If I have 0.020M Br2
then that means I have 0.020mol of Br2
which means if I use 5 ml of it, my concentration will be (0.020mol/0.005L) = 4.0M
is this correct? I am very confused!
The equation you have to remember is:
MiVi = MfVf
For example, if you use have 5.0mL (Vi) of 0.020M Br2 (Mi) and dilute it to a final volume of 25mL (Vf), then you would setup the equations as follows:
(5.0mL)(0.020M) = (25mL)Mf
You can then solve for the final concentration (Mf) and see that it is 0.0040M.
The approach you tried is wrong because 0.020M means that you have 0.020 mol of Br2 in 1L. In 5mL, you would have only (0.020 mol/L) * (0.0050 L) = 0.00010 mol. This amount in 25mL gives a concentration of (0.00010 mol)/(0.025 L) = 0.0040 mol/L = 0.0040 M.
You could have immediately figured out that your initial guess (4.0M) was wrong because diluting a solution will never make the concentration increase!
