Help with piston and atmospheric pressure
The problem involves a cylinder with a frictionless piston subjected to atmospheric pressure, where the cylinder is inverted, doubling the volume of the gas inside while maintaining constant temperature. Participants are discussing the implications of this setup on pressure calculations and the relationships between various pressures involved.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Some participants attempt to derive equations relating the initial and final pressures before and after the cylinder is inverted, using the ideal gas law. Others explore the forces acting on the piston in both orientations, questioning how these forces balance out.
There is ongoing exploration of the relationships between pressures, with some participants providing equations and reasoning based on free body diagrams. While some conclusions are drawn, there is still a request for further clarification and understanding of the concepts involved.
Participants mention a related physics test question regarding heat transfer during the process, indicating a broader context of understanding thermodynamic principles, but the specifics of that question are not fully resolved in the discussion.
shrrikesh
A cylinder with a frictionless piston of mass M and cross section S is placed vertically in an atmosphere of pressure p. The cylinder is rotated 180 degree so that the opening of the cylinder faces down. During the operation the temperature of the gas inside the cylinder is kept constant and the volume of the inside the gas is doubled. The acceleration due to the gravity is denoted by g.
Which of these are correct?
a) p=3Mg/S
b) p=2Mg/S
c) p=Mg/S
d) p=Mg/2S
e) p=Mg/3S
I don't have a clue.
Initially the pressure inside the cylinder is Mg/S.
When it is inverted, the volume doubles. So the pressure reduces to p/2 i.e Mg/2S.
In this position piston is acted by two pressures in the opposite direction.
Can you find the resultant pressure?
Q: How do you eat an elephant?
A: One bite at a time.
This is a lengthy problem, but it isn't too hard - you just have to break it into steps. Lots of little steps.
1. You need an equation relating the pressure in the cylinder BEFORE you flip it upside down (P1) to the pressure in the cylinder AFTER you flip it upside down (P2). Use PV = nRT. You are told T1 = T2 and V2 = 2V1. Solve for an equation for P1 in terms of P2. (I'll call this 'Equation 1' .)
2. Now, I want you to draw two different free body diagrams.
a. The first free body diagram has the cylinder upright. What forces act on the piston? In addition to gravity, don't forget that you have TWO terms relating to pressure: the force of the atmosphere pushing down on the piston, and the force of the gas inside pushing up on the piston. Do you know how PRESSURE in a gas relates to FORCE?
Since the forces are in equilibrium, the sum of all the forces equals zero. This will give you an equation involving Patmosph and P1. (I'll call theis 'Equation 2' .)
b. The second free-body diagram should show the forces on the piston when the cylinder is turned upside down. Gravity still pulls down on the piston, but now the atmospheric pressure is pushing UP and the internal pressure is pulling DOWN.
Again, since the forces are in equilibrium, the sum of all the forces equals zero. This will give you an equation involving Patmosph and P2. (I'll call theis 'Equation 3' .)
3. You now have THREE equations (Equations 1, 2, and 3) and 3 unknowns (P1, P2, and Patmosph). Solve for Patmosph.
Give it a try. Make sure you post your progress and what you've tried if you need any more help (otherwise no one can/will give you more guidance).
so,
P1 = p + Mg/S ... (1)
P2 + Mg/S = p
or, P1 + 2Mg/S = 2p ... (2) (since, P2 = P1/2)
subtracting (1) from (2)
2Mg/s = p - Mg/s
or, p = 3Mg/s
So, the correct answer is option (a).
Thanks for your help.
Guyzz help me out please. Its a very simple question.
There was a major physics test today in brazil for a big university (admittance test n stuff). One of the questions was very similar to this one. But in the end there was this question (multiple answer):
After turning the piston upside down, the gas:
(_) gives heat (_) receives heat (_) there's no heat transfer
the temperature of the gas remained the same. Explain your answer.
I checked no heat transfer and explained that since the gas temperature remained the same, there was no heat exchange.
What do u guyzz think?? Thx
best,
monkey
shrrikesh said:
so,
P2 + Mg/S = p
2Mg/s = p - Mg/s
or, p = 3Mg/s
Can you, please, explain a little bit more. I'm failing to get it. I've drawn the diagrams and all but I just can't get it. Please help.
P1 is the initial pressure.
Look at the piston. There is a upward force produced by air inside, which equals P1 times S. Two downward forces are atmospheric pressure and weight. This gives the first equation, and the second one is similar.
  • · Replies 67 ·
12K
  • · Replies 58 ·
10K
