Strange water boiling phenomenon
The discussion centers on the phenomenon of water boiling after heat sources are abruptly stopped, specifically in microwave ovens and gas cookers. Users observed that when a microwave is halted, the water continues to boil for a brief moment due to superheating, where localized areas of water remain at a higher temperature. Similarly, with gas cookers, the sudden cessation of heat leads to increased steam release, attributed to the condensation of vapor above the water. This phenomenon is explained as an illusion caused by the rapid condensation of vapor and the effects of superheating in microwaves.
  • Understanding of thermodynamics and phase changes
  • Familiarity with microwave heating principles
  • Knowledge of gas cooking methods and heat transfer
  • Basic concepts of superheating and vapor pressure
  • Research the principles of superheating in liquids
  • Explore the thermodynamics of phase transitions in water
  • Learn about heat transfer methods in cooking appliances
  • Investigate the effects of pressure on boiling points
Students of physics, culinary professionals, and anyone interested in the science of cooking and heat transfer phenomena.
Neoφ
Since I'm around that old question about an observed phenomenon came to my mind:
- a cup is filled with water and heated up using a microwave oven. When I see it starting to boil, the oven is stopped abruptly. And while there is no more energy injected into the water, it boils even more for a second when the oven is stopped. So the boiling peak is (just) after the oven is stopped. Looks strange to me.
- one can remark a similar phenomenon using gas.
Something (probably) similar:
- a saucepan is filled with water and heated up using a gas cooker. Then the water boils linearly, and some steam escapes from the top of the saucepan. When the gas is stopped, much more steam comes out of the saucepan for 1-2 seconds. Again, it looks like there is suddenly more heat going to the water, while, on the opposite, the gas was cut and no more (or much less) heat goes to the water.
Does somebody know the reason? Thanks.
I won't comment on the microwave.
However for the stovetop I think it is somewhat of an illusion. When the heat is on the water turns to vapor and stays that way because of the heat. When the heat stops the vapor above the saucepan begins to condense and is visible as tiny droplets.
Microwave ovens can superheat small regions of liquid, which will continue to dump energy into the rest of the water after the microwaves are cut off.
  • · Replies 32 ·
