Why is dE(y) = dEcos(theta) in Electric Field Calculations?
The discussion clarifies the relationship between the electric field components in calculations involving line charges. Specifically, it establishes that dE(y) = dEcos(theta) when theta is defined such that the adjacent leg corresponds to the perpendicular direction of the line of charge. This choice ensures that the vertical components of the electric field cancel due to symmetry, leading to the correct integration process. The confusion arises from the angle selection; using sin(theta) would be appropriate if the angle were defined differently.
  • Understanding of electric field concepts and line charges
  • Familiarity with trigonometric functions in physics
  • Knowledge of integration techniques in calculus
  • Basic principles of symmetry in physics
  • Study the derivation of electric fields from continuous charge distributions
  • Learn about the application of trigonometric functions in physics problems
  • Explore integration techniques specific to electric field calculations
  • Investigate the role of symmetry in simplifying physics problems
Physics students, particularly those in their first or second year, educators teaching electromagnetism, and anyone involved in electric field calculations and analysis.
Lavace
http://www.ph.qmul.ac.uk/~phy210/Ec2.pdf
Question. 3)
Alright I'm just going over things again so I'm ready for year 2 (this is year 1 question).
I already know the method of answering (take a small part dE of the line, form an question of it's electric field on P, intergrate over the length L).
http://www.ph.qmul.ac.uk/~phy210/ECAns2.PDF
There's the answers, I don't understand why, when he also stated that all x-direction forces will cancel due to symmetry, and then says dE(y) = dEcos(theta) <-- isn't that the x-component of the field? I was intending to use sin(theta) until I saw he done that.
Is this because when intergrated we end up with sin(theta)? Why do we use this process?
Thanks!
He uses cos(theta) because he places his theta such that the leg adjacent to theta is the one perpendicular to the line of charge. This is the direction the force will be in, since the vertical components will cancel out.
If you choose the other angle for theta (not the right angle, mind you) then you would in fact use sin(theta). Basically, whether you use sin or cos depends on which of the two angles you're calling theta. The important part is that what matters is that you use the right legs of the triangle...
That's right .
  • · Replies 0 ·
  • · Replies 42 ·
9K
10K
