Calculating dr/dtheta at an arbitrary point and angle
  • Context: Graduate
  • Thread starter Thread starter haytil
    Angle Point
The discussion revolves around calculating the derivative dr/dΘ in polar coordinates at an arbitrary point and angle, particularly in the context of a raytracing simulation. Participants explore the complexities of deriving this value without converting to Cartesian coordinates, addressing both theoretical and practical implications.
  • One participant describes a method for calculating dr/dΘ by converting polar coordinates to Cartesian coordinates, expressing frustration over its inelegance and computational inefficiency.
  • Another participant questions the notion of "pointing in some arbitrary direction," asserting that the derivative of r with respect to θ is a single number and does not vary with direction unless the function involves multiple variables.
  • A later reply attempts to clarify the scenario by suggesting a straight line through the point (r1, Θ1) with a specific slope, seeking to determine the value of dr/dΘ at that point in terms of r1, Θ1, and ΘT.
  • Further responses challenge the clarity of the original question, particularly regarding the definition of variables and the nature of the slope in relation to polar coordinates.
Participants express differing interpretations of the problem, with some agreeing on the need for clarity in defining variables and concepts, while others maintain that the original question lacks coherence. No consensus is reached on the correct approach to calculating dr/dΘ in this context.
There are unresolved assumptions regarding the definitions of variables and the nature of the functions involved. The discussion highlights the complexity of derivatives in polar coordinates compared to Cartesian coordinates, as well as the potential for confusion in terminology.
haytil
In writing a computer raytracing simulation using polar coordinates, I've come across a simple problem: I need to calculate the value of dr/dΘ at an arbitrary point (in polar coordinates), pointing in an arbitrary direction (given as an angle).
So if point 1 (p1) is given by the coordinates (r1, Θ1), and I create a ray from that point, pointing at an angle Θ2 with respect to p1 (not with with respect to the origin), I need to know the value of dr/dΘ along that ray at that starting point.
Of course, Cartesian coordinates is much simpler: dx/dy as a function of Θ2 does not depend on the values of x and y at the point you're trying to calculate from. In polar coordinates, however, given an arbirtrary value Θ2, dr/dΘ will change depending on what the value of r is at the point you're trying to calculate from. Beyond that, however, I do not know the explicit formula that I need. So my current algorithm/equation relies on converting to cartesian coordinates and then doing the calculation.
It is as follows:
dx = cos(Θ2)
dy = sin(Θ2)
x1 = r1 * cos(Θ1)
y1 = r1 * sin(Θ1)
(This assumes dx << x1 and dy << y1. If not, dx and dy are divided by a large constant)
rT = sqrt( (x1+dx)^2 + (y1+dy)^2 )
ΘT = arctan( (y1 + dy) / (x1 + dx) )
Add 2pi or pi to thetaT as necessary (depending on which quadrant the point p1 is in)
dr = rT - r1
dΘ = ΘT - Θ1
dr/dΘ = (rT - r1) / (ΘT - Θ1)
This algorithm is undesirable both because it is inelegant (in its roundabout way of first converting to cartesian coordinates to do the calculation) and slow to run on the machine (trig functions and square roots, when unnecessary, slow things down a great deal, and I'm having many problems with computer-related precision limits which can likely be avoided with a more straightforward algorithm).
I'm sure there's a much simpler solution, involving only polar coordinates, and I'm frustrated that such a seemingly simple problem is stumping me. Can anyone help out?
I don't understand what you mean by "pointing in some arbitrary direction". If r is a function of [itex]\theta[/itex], then its derivative at any point is a single number, not a vector, and does not "point" in any direction. In order to have a different derivative in different directions, you would have to have a function of at least two variables, say f(r,[itex]\theta[/itex]), not r([itex]\theta[/itex]).
I'm sorry, I'm not being very clear. The scenario I'm trying to handle is quite simple, I'm just not explaining it right. Let me try again:
Imagine a straight line that passes through the point (r1, Θ1) and that the slope of the line at that point is sin(ΘT)/cos(ΘT).
What is the value of dr/dΘ of the line at that point? (In terms of r1, Θ1, and ΘT)
Your question still doesn't make sense. What is "T"? The slope of a straight line is a constant and so T should not be a variable. Or do you mean [itex]\Theta T[/itex] as "[itex]\Theta_T[/itex], a constant? If that is the case then the line, in xy-coordinates (since the slope of a line is defined in terms of xy- coordinates), is given by
[tex]x= \left(\frac{cos(\Theta_T)}{sin(\Theta_T)}\right)s+ r_1cos(\theta_1)[/tex]
[tex]y= \left(\frac{cos(\Theta_T)}{sin(\Theta_T)}\right)s+ r_1sin(\theta_1)[/tex]
and, since [itex]x= r cos(\theta)[/itex], [itex]y= r sin(\theta)[/itex],
[tex]r cos(\theta)= \left(\frac{cos(\Theta_T)}{sin(\Theta_T)}s+ r_1cos(\theta_1)[/tex]
[tex]r sin(\theta)= \left(\frac{cos(\Theta_T)}{sin(\Theta_T)}s+ r_1sin()\theta_1)[/tex]
we have, by squaring and adding,
[tex]r^2= \left(\left(\frac{cos(\Theta_T)}{sin(\Theta_T)}\right)s+ r_1cos(\theta_1)\right)^2+ \left(\left(\frac{cos(\Theta_T)}{sin(\Theta_T)}\right)s+ r_1sin(\theta_1)\right)^2[/tex]
or
[tex]r= \sqrt{\left(\left(\frac{cos(\Theta_T)}{sin(\Theta_T)}\right)s+ r_1cos(\theta_1)\right)^2+ \left(\left(\frac{cos(\Theta_T)}{sin(\Theta_T)}\right)s+ r_1sin(\theta_1)\right)^2}[/tex]
Dividng the second equation by the first
[tex]tan(\theta)= \frac{sin(\theta)}{cos(\theta)}= \frac{\left(\frac{cos(\Theta_T)}{sin(\Theta_T)}s+ r_1sin()\theta_1)\right)}{\left(\frac{cos(\Theta_T)}{sin(\Theta_T)}s+ r_1cos(\theta_1)\right)}[/tex]
37K
