Velocity of compressed air blowoff
The discussion centers on managing noise levels from a centrifugal compressor blowoff line due to high velocity in the piping system. The setup includes a 3" globe valve transitioning to a 4" diameter Schedule 40 pipe, which then increases to an 8" pipe before a silencer. With a compressor capacity of 7400 ICFM and a pressure of 350 psi, the calculated velocity through the 4" pipe can exceed sonic velocity, leading to choked flow and excessive noise. To mitigate this, it is essential to maintain backpressure on the valve and consider using a specialty valve designed to vent high-pressure air without reaching sonic velocity.
  • Understanding of fluid dynamics and flow velocity calculations
  • Familiarity with piping standards, specifically Schedule 40 pipe dimensions
  • Knowledge of compressor operation and modulation effects
  • Experience with pressure drop calculations and their impact on flow
  • Research methods to calculate acceptable flow velocities in piping systems
  • Explore specialty valves designed for venting high-pressure air
  • Learn about backpressure regulation techniques in pneumatic systems
  • Investigate noise reduction strategies for compressed air systems
Engineers, pneumatic system designers, and maintenance personnel involved in compressor operations and noise management in industrial settings.
mook68
Here's my situation - I have a centrifugal compressor blowoff line that is creating too much noise. I am being told that the velocity through the pipe may be too high. Values as follows -
3" globe valve increasing to 4" diameter sch 40 pipe 17.5 feet long, increase to 8" sch 40 before silencer.
350 psi before valve blowing off to atmosphere, ICFM capcity of compressor is 7400 but blowoff will never see that due to modulation.
How can I calculate the acceptable velocity of 4" pipe (or any size pipe) blowing off to atmosphere w/o shock wave noise? and is that considered "sonic velocity"?
I have a customer very upset about the noise level and I am stumped!
To avoid "choked flow", ie, sonic velocity, you need to be below something like 65 psi (not sure exactly) of pressure drop anywhere, in addition to having big enough pipes to pass 7400 cfm at below sonic velocity.
7400 CFM through a 4" pipe is 1400 fps, which is above the speed of sound, but as you say unlikely to ever occur. So the only place you could get sonic velocity is in the valve itself. And that's pretty likely since when the valve cracks open, you'll have 350 psi on one side and 0 on the other and guaranteed choked flow through it.
What you need is a way to ensure that the backpressure on the valve is always high enough that you don't get a 65 psi drop across it. You need some sort of regulating device at the valve (instead of the valve?). I don't spec air compressors myself, but I would think that there would be a specialty valve that is designed specifically for that task (venting high pressure air to atmosphere without reaching sonic velocity).
  • · Replies 19 ·
  • · Replies 45 ·
  • · Replies 39 ·
17K
14K
