| Thread Closed |
Charge distribution (Gauss law) |
Share Thread | Thread Tools |
| Aug1-09, 09:57 AM | #1 |
Claim:
A charged sphere will have it's charges disperse (uniformly for symmetrical objects) on the outer surface. Proof: Consider a sphere charged to some amount q. If we take small gaussian surfaces within the sphere, it will have [tex]\vec{E} = 0[/tex] on the closed gaussian sphere [since it is an equipotential surface]. Therefore, the electric flux is zero, so the electric charge from the small gaussian surface will have zero electric charge enclosed [Note: Gauss law states- the electric flux through any closed surface is proportional to the enclosed electric charge. Now if we take enough small gaussian surfaces to fill the entire sphere, we find analogously the charge enclosed from all little gaussian spheres is zero. Therefore, the charge enclosed in the larger sphere is zero. But it has been charged to charge q, so the only possibility is that charge resides on the surface. Question: Is the proof above reasonable? Does this same reasoning apply to a single charged plate? Will charge distribute along the plate-surface where it was charged, and leave the other side uncharged [I can see why conducting spheres is a good shield in the inside, but cannot see how solid conducting plates can be used as shields respectively]? |
| Aug1-09, 12:26 PM | #2 |
| Aug1-09, 12:44 PM | #3 |
So charge will not simply be on one side of the plate? Because, plate conductors is often used in electronics to shield the devices from nearby electric fields. If both of sides of the plate becomes charged, then the device facing either sides will be effected, and contradicts the whole notion of shielding.
| Aug1-09, 12:53 PM | #4 |
Mentor
I think the idea is that the presence of an applied electric field causes the charges within the conductor to distribute themselves along (all) out surfaces in such a way that an electric field is set up within the conductor -- one that has the effect of cancelling out the applied field. So the net electric field inside the conductor is zero. This is how the shielding is accomplished. None of the applied electric field is allowed to penetrate to the opposite side of the conductor. I believe this is the principle of operation behind a Faraday cage.
| Aug1-09, 01:01 PM | #5 |
| Aug1-09, 01:04 PM | #6 |
| Aug1-09, 01:08 PM | #7 |
Mentor
EDIT: This is really a case where a picture is worth a thousand words. I'd recommend drawing one. |
| Aug1-09, 01:28 PM | #8 |
Thanks, JL |
| Aug1-09, 01:52 PM | #9 |
Sorry to do this, but could you explain how the fields cancel on the opposite side of the particle that created the applied electric field? To me it seems the fields created by the positive and negative charges from the plate cancel outside the plate. But the electric field from the source (charge that induced applied electric field) is still present. So at the opposite end of the applied charge exists the applied electric field, is that correct?
| Aug1-09, 02:00 PM | #10 |
| Aug1-09, 02:20 PM | #11 |
OK, here is a picture as an attachment. The blue area is a piece of the conducting slab. Note that electric field lines start at + charges and stop at - charges. The black field lines that are generated by charges outside the conductor are canceled by the red lines so that the net field inside the conductor is zero as it should.
| Aug1-09, 03:28 PM | #12 |
Mentor
The wikipedia page for "Faraday Cage" has a great animation.
| Aug1-09, 05:15 PM | #13 |
| Aug1-09, 09:33 PM | #14 |
Mentor
| Thread Closed |
| Thread Tools | |
Similar Threads for: Charge distribution (Gauss law)
| Gauss' Law for a point charge | Introductory Physics Homework | 6 | ||
| Normal (Gauss) Distribution questions | Set Theory, Logic, Probability, Statistics | 3 | ||
| The work required for adding a charge to an infinite charge distribution | Advanced Physics Homework | 1 | ||
| boltzmann and gauss distribution | Atomic, Solid State, Comp. Physics | 0 | ||
| Using Gauss (Divergence) theorem to find charge distribution on a conductor | Advanced Physics Homework | 3 | ||
