How to Find the Surface Area of a Revolution?
The discussion revolves around finding the surface area generated by revolving the function y = x^3/3 about the x-axis, specifically for the interval 1 <= x <= sqrt(7).
  • Participants discuss the setup of the integral for the surface area and explore substitution methods to simplify the integral. There are questions about the correct form of the integral and the inclusion of constants such as 2π.
Some participants have provided guidance on the substitution method and noted the importance of including constants in the integral. There is an ongoing exploration of how to proceed with the integration process, with no explicit consensus reached yet.
There are indications of potential confusion regarding the correct formulation of the integral and the necessary constants. Participants are also reflecting on their understanding of the substitution technique.
TheLegace
Find area of surface generated by revolving about x-axis.
y=x^3/3 1<=x<=sqrt(7)
find f'(x) = x^2
A = integral[ (x^3/3) * [(1+(x^2)^2] ^(1/2) ] ]dx
= integral[ (x^3/3) * [(1+x^4) ^(1/2) ]dx
I just don't know where to go from here.
Any help is appreciated,
Thank You.
Ordinary substitution: let u = 1 + x^4.
I'm assuming that you have the correct integrand. If so, this substitution will help you out.
find f'(x) = x^2
Thank You.
You forgot the [tex]2\pi[/tex] in your equation, but you probably have that on paper. Here's what the integral should look like.
[tex]A=\frac{2\pi}{3}\int^{\sqrt{7}}_{1}{x^{3}\sqrt{1+x^{4}}dy[/tex]
Oh whoops, ok well having that in there, how could I continue this problem?EDIT: I see how this can be solved, substition method.
Thank You.
Do what Mark44 said to do.
[tex]u=1+x^{4}[/tex]
[tex]du=4x^{3}dx[/tex]
[tex]du=\frac{x^{3}}{4}dx[/tex]
Make that du = 4x3dx
Haha oops.
  • · Replies 20 ·
