Prove Positive Operators Sum is Positive on V
  • Thread starter Thread starter evilpostingmong
    Operators Positive
The discussion revolves around proving that the sum of any two positive operators on a vector space V is also positive. The context involves self-adjoint operators and their properties in linear algebra.
  • Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants explore the definitions of positive operators, considering examples and properties such as self-adjointness and eigenvalues. There are attempts to establish inner products and discuss the implications of positive definiteness.
Some participants have proposed reasoning involving eigenvectors and inner products, while others question the assumptions made regarding the choice of vectors. There is acknowledgment of the need for clarity on definitions and properties of positive operators, with some guidance offered on maintaining generality in vector selection.
There is a discussion about the definitions of positive operators and the distinction between positive and positive-definite matrices. Some participants express uncertainty about the implications of using eigenvectors versus arbitrary vectors in their proofs.
evilpostingmong
Prove that the sum of any two positive operators on V is positive.
This problem seems pretty simple. But I could be wrong. Should I name two
positive operators T and X such that T=SS* and X=AA*? I have a bad
history of seeing a proof and thinking "wow, this'll be cake" which leads to lazy thinking.
Should I just choose two vectors v1 and v2 and establish two inner products, <SS*v1, v2>+<AA*v1, v2>?
I know that A* is real if X is positive, same goes for S. So <AA*v1, v2>=<Av1, Av2>=<A^2v1, v2>. If I'm
right here, its easy street.
And what is V? Is it vector space ?
yes its a vector space. So V is invariant under T (this chapter deals with self-adjoint operators, so I think that this is what is to be assumed).
I have a proof in mind but won't post it if what I said (in the first post ) is wrong.
Ok let V be invariant under T. Now let v be an eigenvector under T.
Let V be invariant under X. let v be an eigenvector under X.
Now since T and X are positive, we assume that <Tv, v> >=0 and <Xv, v> >=0 and that
T and X are invariant. Now if <Tv, v> >=0 and <Xv, v>=0, then <(T+X)v, v>=<Tv, v> which
is >=0. If T is a 0 map, <(T+X)v, v>=<Xv, v> which is also >=0. If T and X are not 0 maps, and T and X are both positive, then <(T+X)v, v> is > both <Tv, v> and <Xv, v> since both <Tv, v> and <Xv, v> are >0 if neither are 0 maps. Now if both T and X are 0 maps, then <(T+X)v, v>=0, also >=0.
Now we must show that T+X is self adjoint Since we assume that T and X are positive, T=T* and X=X*. So (T+X)v=Tv+Xv and (T*+X*)v=T*v+X*v. Since Tv=T*v and Xv=X*v, Tv+Xv= T*v+X*v. Therefore T+X is self adjoint.
Ignore me, just here to mark the post and will do it later.
I assume a positive operator is a positive-definite matrix(correct me if I am wrong), do you know what the definition is?
You are correct. My book says that a positive definite operator is a positive operator
but didn't use a matrix when describing one. But I assume you're correct in that
by the def of a positive operator: 1. Must be self adjoint 2. <Tv, v> >=0
I would imagine the same to be true for the matrix: its conjugate transpose must equal
the original matrix when dealing with a complex space and its transpose must equal
its original form when dealing with a real space. So itself adjoint. And <Tv, v> >=0.
Which implies all eigenvalues of T must be >=0. Oh and when I said original matrix
I meant the matrix you want to "transpose".
In the 4th post you take v as an eigenvector, I really don't see why,since the definition requires <Tv, v> >0(I think the >=0 case is semi positive definite) for any v, another fallacy in your proof is X and S may not share the same eigenvector. And positive-definite matrix can not be 0 matrix, you don't need to discuss it.
Just let v be any vector, the proof will be OK.
Whoops, my bad. As long as the scalar <Tv, v> (say Tv=a1v1+...+anvn where Tv=/=cv where c is some scalar) is >=0, T is positive.
So if I were to go back and revise, just replace "eigenvector" with any vector and the proof
is correct, right? And yes, T and S may not share the same eigenvector.
For example, if T were a 3x3 matrix where every entry on this matrix differ, and
S were a 3x3 identity matrix, its clear that an eigenvector of S is (1 1 0) but
(1 1 0) may not be an eigenvector of T since T(1 1 0) would amount to
(a+b, d+e, 0) where a+b=/=d+e so (a+b, d+e, 0) is not a scalar multiple of (1 1 0).
But we are only focusing on the scalars <Tv, v> and <Sv, v>. So v is arbitrary.
btw this assumes that the basis for V is {(1 1 0), (0 0 1), (0 1 1)}
  • · Replies 43 ·
