| Thread Closed |
Anyone know of an internal liner material to protect against internal corrosion |
Share Thread | Thread Tools |
| Aug6-09, 02:29 AM | #1 |
Does anyone have any experience with liner material for application on pipework with internal corrosion/erosion?
Pipes are designed to hold water/methanol vapour Normal operating conditions for the pipes: Temperature • Average temp - 172F • Max temp - 267.1F Pressure • Average internal pipe pressure - 5.4 PSIG • Max internal pipe pressure - 15 PSIG Acidity level • pH level of ~3.5-5.5 Chloride level • 90000 – 120000ppm Fines of up to 40 microns collect in the system and circulate the pipe work within the liquid which has a max flow rate of 200USPGM. Process treatment in the pipes consists of: 1) Oxygen Scavenger (sodium bisulphate) 2) Scale Inhibitor (polymer based) 3) Corrosion Inhibitor (organic) 4) Defoamer (silicon polymer) Failure mechanisms/ Anomalies detected include: • Weld root corrosion • Pitting corrosion • Synergistic effect of erosion/corrosion • Impingement corrosion If anyone has experience with using an internal liner or lining material with applications similar to the above any feedback would be much appreciated. |
| Aug7-09, 11:33 PM | #2 |
I am not a mechanical / materials engineer. However, maybe teflon-coated steel? Unfortunately, if pitting / scouring is a problem, that'll probably scrape off the coating.
| Aug7-09, 11:54 PM | #3 |
What is the dia. of pipe ? I mean can anybody enter inside to coat.
If yes, I would suggest Teflon spraying with only upto 2.5 micron thickness other wise pitting problem. Tom |
| Aug9-09, 03:51 PM | #4 |
The pipe has a 4" dia and the section consists of T-joints and tight bends.
Solutions I have looked at so far include Cladding and Weld Overlay but the process costs increase dramatically as the pipe dia decreases. Cheers for your reply |
| Aug9-09, 08:44 PM | #5 |
What about some sort of ceramic liner? Maybe a powder-coat application?
| Aug10-09, 11:08 AM | #6 |
Recognitions:
I have experience with epoxy based liners for steel underground tanks but have never seen anything for in-situ pipe installation.
| Thread Closed |
| Thread Tools | |
Similar Threads for: Anyone know of an internal liner material to protect against internal corrosion
| Internal Liner Material... | Materials & Chemical Engineering | 1 | ||
| Internal Energy | Introductory Physics Homework | 3 | ||
| E.m.f and internal resistance | Introductory Physics Homework | 2 | ||
| Internal resistance... | General Physics | 1 | ||
| Internal Energy | Introductory Physics Homework | 2 | ||
