Dropping bar magnet through loop of wire
  • Context: Undergrad
  • Thread starter Thread starter ninjadrummer8
    Loop Magnet Wire
The discussion centers on the electromagnetic induction observed when a bar magnet is dropped through a loop of wire. It confirms that as the magnet approaches the wire, the induced current increases, and as it exits, the current decreases. During the brief moment the magnet is fully within the loop, the rate of change of the magnetic field (dB/dt) is zero, resulting in no induced current. The current exhibits a bipolar signal pattern, reflecting the polarity of the magnet as it passes through the coil.
  • Understanding of electromagnetic induction principles
  • Familiarity with Faraday's Law of Induction
  • Knowledge of operational amplifiers and their applications
  • Experience with measuring instruments like low impedance ammeters
  • Study Faraday's Law of Induction in detail
  • Learn about the behavior of induced currents in coils
  • Explore the design and function of voltage integrators using operational amplifiers
  • Investigate the effects of magnetic field changes on current induction
Physics students, electrical engineers, and hobbyists interested in electromagnetic theory and practical applications of induction in circuits.
ninjadrummer8
Ok I have 2 questions about this.
So I know that a current is induced when the magnetic field changes near the wire. So say I dropped the magnet North end up and South end down through this wire, the current would increase as it was nearing it, and decrease as it leaves it.
1) is this correct?
2) what happens in the short time period that the magnet is still passing through the coil? is the current 0?
If your signal is going into a low impedance ammeter, the current would go positive (or negative depending on polarity of ammeter), go back to zero while the magnet is passing through the wire, then go negative (opposite polarity) as the other pole passes through the loop. It is a bipolar signal. The reason it goes to zero in the middle of the magnet is because dB/dt through the loop is zero.
If you built a voltage integrator with an operational amplifier, the integrated voltage would stay positive until the other end of the magnet passed through the loop.
  • · Replies 27 ·
18K
