Conservation of mechanical energy
The discussion revolves around the conservation of mechanical energy in non-conservative systems, particularly in the context of rocket propulsion. Participants explore the implications of dissipative forces and the conditions under which mechanical energy may or may not be conserved.
  • Participants examine the role of dissipative forces in non-conservative systems and question whether mechanical energy can be conserved under certain conditions, such as neglecting air resistance in rocket propulsion. They also discuss the implications of gravitational forces on mechanical energy conservation.
The discussion is active, with participants sharing insights and questioning assumptions about mechanical energy conservation. Some guidance has been offered regarding the nature of conservative and non-conservative forces, but no consensus has been reached on specific scenarios.
Participants are considering various forces acting on the rocket, including gravity and propulsion, and how these affect the conservation of mechanical energy. There is an acknowledgment of the complexity introduced by non-conservative forces.
Amith2006
I have a doubt on total mechanical energy conservation in a non conservative system. I think, in such a system there are dissipative forces as a result of which the total mechanical energy is not conserved because there may be loss of energy in the form of heat or other forms. In the case of rocket propulsion, if the air resistance is neglected it becomes a conservative system and hence the mechanical energy is conserved while dealing non relativistically. Is it right?
total mechanical energy = K.E + P.E
Yep, sounds right. But is there a specific problem you're thinking of?
Total mechanical energy is not conserved when non conservative forces that do work act.
How about a gain in total mechanical energy?
Suppose for simplicity that the rocket is propelled horizontally, starting from rest and and accelerating to some high speed. Is mechanical energy (in this case kinetic energy) conserved (delta KE = 0) or increasd (delta KE>0)?
[/QUOTE]
Ya! In that case K.E will increase. But if gravity is taken into account it will follow a parabolic path and then P.E comes into picture isn't it?
I assume the parabolic path you are talking about is the path of the object taken when it is subject to gravity forces only, as would occur if the rocket, assumed not in orbit, ran out of fuel. This is a conventional parabolic motion problem, in which case, since only a conservative force acts (gravity), total mechanical energy is conserved (KE + PE is constant, that is , the change in KE plus the change in PE sums to zero). But in the more general case when the rocket is subject to other forces besides gravity, like the propelling force from the rockets escaping gasses, its motion could be in any shaped curve. The point I am trying to make is that when an object is subject to non conservative forces that do work, total mechanical energy is not conserved (delta KE plus delta PE is not equal to zero). Incidentally, if you look up the definition of a non conservative force in Wiki, it is likely to confuse the living daylights out of you. Basically, in Mechanics, gravity and ideal springs/ideally elastic bodies, exert conservative forces. Most every other force is non conservative. The literature usually talks about friction being a non conservative force. Correct. But tension, normal forces, pushing forces, applied forces, and all other so called 'contact' forces, are also non conservative in nature.
Thanx guys.
