Discovering Hose Physics: Calculating Water Speed from Nozzle Adjustment
But we know thatv = v0 + gtSo we can writeg sqrt(2s/g+1) = v0 + gt.This gives us immediately the initial velocity of the water.In summary, the conversation is about solving a physics problem involving a garden hose and the speed of water leaving the nozzle. The initial equation used was incorrect and needed to be corrected. The water does not have zero velocity when it hits the ground, and the correct equation for velocity is v=v0+at. The solution to the problem involves using the equation t = v/g + sqrt((v/g)^2 + 2s/g)
mt2568
[SOLVED] Hose Physics
Suppose you adjust your garden hose nozzle for a hard stream of water. You point the nozzle vertically upward at a height of 1.5 m above the ground (the hose is 1.5 m off the ground). When you quickly move the nozzle from the vertical you hear the water striking the ground next to you for another 2.0 s. What is the water speed as it leaves the nozzle?
Hi mt,
I don't know if you noticed the Sticky I put at the top of this forum ("Read This Before Posting"), but it states the policy here that we want to see how you started and where you got stuck, then we help you through the rough spots.
Thanks,
Didn't notice that, but I left my work on a different thread, forgot to put it here...
This how I got my answer, not sure if it was right though...
v = V0T + 2AT^2 (2nd Kinematic equation)
x-1.5 = v0(2s) + 2(9.8m/s^2)(2s)
When T = 2, then x- 1.5 is zero (When the water hits the gound the velocity of the water is zero)
v0 = -19.6m/s or 19.6 m/s
Forgot to divide the 2s, its 9.8 m/s not 19.6
Not quite. That should be:
x=x0+v0t+(1/2}at2
Just change the 2 to (1/2)[color] and recalculate.
Yes.
No. The speed of the water is only zero at the top of the trajectory. By the time it hits the ground, it will be moving even faster than it was when it left the nozzle.
You'll have to correct the mistakes noted above and try again.
v = V0T + .5AT^2
0 m/s = V0(.30s) + .5(9.80 m/s^2)(2s)^2
V = -65.3 m/s or 65 m/s
This doesn't seem right, a garden house shooting 65+ feet in the air! It must have something to do with the 0 for the final velocity (the water resting on the ground). Other than that I really can't see what I am doing wrong.
v = V0T + .5AT^2
You didn't correct the first mistake I pointed out.
The equation should be:
x(not v!)=x0+v0t+(1/2)at2
Sry, typo, its hot out here :), despite that fact I made the x equal x-1.5. When you set T = 2, x - 1.5 = 0 because when the water hits the ground it no longers has a velocity.
Yeah, it's hot here too. :frown:
Whoa!
First, I am supposing that you set x=0 at ground level, so x-1.5 would indeed equal zero. But that has nothing to do with the velocity of the water.
Second, it is not true that the water does not have a velocity when it hits the ground. Indeed, its speed is greater when it hits the ground than it was when it left the nozzle. I already said that in my first post.
The equation for velocity is:
v=v0+at
In this case, a=-g (I take g to be a positive number), and you can see for yourself that v is definitely not zero when the water hits the ground. To find that out, you have to solve for t in the equation for x, then plug t into the equation for v.
But we aren't solving for V, we are solving for initial velocity. Moreover, how can I solve t in the equation for x if I don't the initial velocity:
x = x0 + v0t +.5at^2
X = 0
x0 = 1.5 m
T = unknown
A = 9.8 m/s^2
V0 = unknown
Two variables? Something has to be done with the piece of information telling us that the water continues to hit the ground for 2 minutes, I just don't know what.
Correction: 2 seconds
I know that. I told you that you can solve for v to convince yourself that the speed of the water is not zero when it hits the ground. I said that because you told me twice that it is zero, and that is wrong.
X = 0
x0 = 1.5 m
T = unknown
A = 9.8 m/s^2
V0 = unknown
But you were given T. They tell you that you water continues to land next to you for 2 seconds. That means it took 2 second for the water to go up and then come back down.
X = 0
x0 = 1.5 m
T = 2 secs
A = 9.8 m/s^2
V0 = unknown
0 m = 1.5 m + v0(2s) + .5(9.80m/s^2)(4 s) =
0 m = 1.5 m + v0(2s) + 19.6 m/s^3 =
0 m = 21.1m/s^3 + v0(2s) =
-21.1m/s^3 = v0(2s) =
-10.55 m/s^2 = v0
Isn't this a form of acceleration rather than velocity?
No, you just made a mistake with the t2 term.
(2s)2=4s2, but you have 4s.
Thank you very much for your helf throughout the day; it is much apprectiated.
Hi, last time I looked at this, there were no replies. In the meantime, I found a solution. I think it's safe to post it now, since so much discussion has been gong on...
In a free fall from height h, the time is
t = sqrt(2h/g).
In this problem, we have a rise of h, and then a fall of h+s (where s = 1.5m). So,
t = sqrt(2h/g) + sqrt(2(h+s)/g).
Now, if we substitute h = v^2/2g, we get
t = v/g + sqrt((v/g)^2 + 2s/g).
It's quite easy to solve this for v.
1. How do you calculate water speed from nozzle adjustment?
To calculate water speed from nozzle adjustment, you will need to know the diameter of the hose, the diameter of the nozzle, and the pressure of the water. Then, you can use the formula Q = AV to calculate the water flow rate, where Q is the flow rate in gallons per minute, A is the cross-sectional area of the hose, and V is the velocity of the water. You can then use the formula V = √(2gh) to calculate the water speed, where g is the acceleration due to gravity and h is the height difference between the nozzle and the ground.
2. How does water pressure affect the water speed?
The water pressure directly affects the water speed. The higher the water pressure, the faster the water will flow through the hose and out of the nozzle. This is because the pressure creates a force that pushes the water through the hose, increasing its velocity.
3. What is the relationship between nozzle size and water speed?
The size of the nozzle has a significant impact on the water speed. A smaller nozzle will create a higher pressure, resulting in a faster water speed. On the other hand, a larger nozzle will have a lower pressure, resulting in a slower water speed.
4. How can you adjust the nozzle to increase water speed?
To increase water speed, you can adjust the nozzle by decreasing its size or increasing the water pressure. This will create a narrower opening for the water to flow through, increasing its velocity as it exits the nozzle.
5. What factors can affect the accuracy of calculating water speed from nozzle adjustment?
There are several factors that can affect the accuracy of calculating water speed from nozzle adjustment. These include irregularities in the hose or nozzle, changes in water temperature, and variations in water pressure. It is essential to ensure that all measurements are precise and consistent to achieve accurate results.
