Gaussian Surface: Electric Field & dA Visualization
The discussion revolves around visualizing the area element dA in the context of Gaussian surfaces used for calculating electric fields due to infinitely long line charges and infinite plane sheets of charge. Participants are exploring the relationship between the electric field direction and the orientation of the area element dA.
  • Participants discuss the orientation of the area element dA in relation to the electric field, questioning how to visualize it correctly. There are attempts to clarify the direction of dA in different scenarios, such as cylindrical and planar Gaussian surfaces.
Some participants have provided guidance on the orientation of dA, suggesting it should be perpendicular to the surface and aligned with the electric field direction. Others have raised points about the contributions of different surfaces in the calculations, indicating a mix of interpretations and ongoing exploration of the topic.
There is mention of the need for visual aids to better understand the orientation of dA, and some participants express confusion over the correct choice of direction for dA in different geometries. The discussion reflects a learning process with varying levels of understanding among participants.
logearav
In the case of calculating electric field due to an infinitely long line charge, we assume cylinder to be a gaussian surface and electric field and small area element of the cylinder acts along the same direction at the curved surface and they act perpendicular direction at the plane faces.
in the case of electric field due to an infinite plane sheet of charge we again assume cylinder to be a Gaussian surface but in this case at the plane faces electric field and surface element dA acts along the same direction and they act perpendicular along the curved surface. i am confused. please let me know how to visualise area element dA. i know electric field vector acts perpendicular to the surface but how to know the direction of the area element dA? help in this regard is greatly appreciated
Remember, dA represented as a vector has a direction perpendicular to the surface element. If you know the direction of the electric field, a good choice of the dA vector orientation is in the same direction as the (local) electric field which makes the surface element perpendicular to the local electric field. Then the dot product E.dA becomes just the product of magnitudes E dA and you don't have to worry about the cosine of the angle between them because it is 1.
So if you have a positive point charge that radiates electric field lines radially outward, what would be a good choice of dA? And when you have many such dAs next to one another, what kind of Gaussian surface do you get?
but sir, if i draw a cylinder the plance face is elliptical in shape. dA should be perpendicular to the surface. i can draw dA in top direction, right direction and left direction. all these directions are perpendicular to the surface. what is the correct choice of direction.
The correct choice of direction is perpendicular and away from the cylinder. Please look up "Gaussian surface" in wikipedia. There is a decent drawing of a cylindrical Gaussian surface for a linear charge distribution with elements dA drawn in. A picture is worth a thousand words. If you still have questions after you study the wikipedia article, please ask again.
I think people are glossing over the fact that there is a radial ds vector as well. Just because the flux is zero there doesn't mean it isn't a valid direction. All three surfaces need to be taken into account, the two caps and the cylinder itself. When you do the calculations you will see that only the two caps contribute to the field and I guess this is why everyone is ignoring the cylinder itself.
Thanks a lot mr.kuruman and mr. cyosis. now i understood the concept. thanks for sparing your valuable time.
  • · Replies 18 ·
