Integrate the on axis field of finite solenoid from a thin shell one, HELP
The discussion focuses on integrating the on-axis magnetic field of a finite solenoid derived from the thin shell solenoid equation. The user, Samuel, references specific equations from the provided links and seeks clarification on obtaining the (r2-r1) term in the finite solenoid equation. The solution involves integrating the magnetic field contribution from infinitesimal solenoids of radius r, thickness dr, and length l, using the expression dB = (μ₀N di / 2l) * [(x₂ / √(x₂² + r²)) - (x₁ / √(x₁² + r²))]. The key to solving the problem lies in expressing di in terms of dr through current density.
  • Understanding of electromagnetic theory, specifically solenoid equations.
  • Familiarity with calculus, particularly integration techniques.
  • Knowledge of magnetic field concepts and current density.
  • Ability to interpret mathematical expressions in physics.
  • Study the derivation of the thin shell solenoid equation in detail.
  • Learn about the integration of magnetic fields from finite solenoids.
  • Explore the concept of current density and its applications in electromagnetism.
  • Review advanced calculus techniques relevant to physics problems.
Physics students, electrical engineers, and anyone involved in electromagnetic field theory or solenoid design will benefit from this discussion.
demon_samuel
Dear all,
i met a problem that i couldn't get the on axis field of a finite solenoid that integrating from a thin shell solenoid equation.
The thin shell equation link:
http://www.netdenizen.com/emagnet/solenoids/thinsolenoid.htm
And the on axis finite solenoid equation link:
http://www.netdenizen.com/emagnet/solenoids/solenoidonaxis.htm
If i was right, the integral of (a/sqrt (a*a+r*r)) dr should be a*ln(r+sqrt(r*r+a*a)), if so i couldn't figure out how to get the (r2-r1) term in the second link equation.
Thank you for your attention
Samuel
To get the second expression from the first, you need to integrate over dr from r1 to r2. You do this by adding "solenoids" of radius r, thickness dr, and length l carrying current di. According to the first expression, the contribution from one such solenoid is
[tex]dB = \frac{\mu_{0}N di}{2 l}[\frac{x_{2}}{\sqrt{x^{2}_{2}+r^{2}}}-\frac{x_{1}}{\sqrt{x^{2}_{1}+r^{2}}}][/tex]
Before you integrate, you need to express di in terms of dr. Hint: Think in terms of current density.
Thank you very much, i got the answer.
12K
9K
21K
11K
9K
