Calculating Torque and Power Requirements for Turning a Shaft
  • Context: Undergrad
  • Thread starter Thread starter bocceball
    Force Shaft
The discussion focuses on calculating the torque and power requirements for turning a 750mm diameter shaft with a mass of 1,000kg at a velocity of 160 RPM, while a weight of 2,500kg is applied to the shaft. Key considerations include the distribution of the 2,500kg weight and the distinction between force and horsepower. Understanding these factors is crucial for accurate calculations of the required torque and power for the shaft's operation.
  • Understanding of torque calculations
  • Knowledge of horsepower and its relationship to force
  • Familiarity with rotational dynamics
  • Basic principles of mechanical engineering
  • Research torque calculation formulas for rotating shafts
  • Learn about the relationship between horsepower and torque
  • Explore the effects of weight distribution on torque requirements
  • Study rotational dynamics in mechanical systems
Mechanical engineers, students in engineering disciplines, and anyone involved in designing or analyzing rotating machinery will benefit from this discussion.
bocceball
What is the force (horsepower) required turn a 750mm diameter shaft with a mass of 1,000kg, at a velocity of 160 rpms, with a weight of 2,500kg applied to the shaft?
Thanks.
Thanks.
Welcome to the PF. What is the context of your question? Is it homework, coursework, a school project, or something you are designing and building?
For one thing you need to decide how the 2500 kg weight is applied...how it's distributed about the shaft...for example if it's on a rigid bar hanging from a horizontal shaft that whole assembly will not go easily...if that's the weight of the shaft itself, evenly distributed, a lot less torque is required...
Also, force and horsepower are two different physical entities...are you aware of their relationship??
  • · Replies 24 ·
  • · Replies 19 ·
