Can I Use a Metal Spring to Replace a Wooden Bow for My DIY RPG Weapon?
  • Thread starter Thread starter Matt_741
The discussion revolves around the feasibility of using a metal spring as a replacement for a wooden bow in the construction of DIY RPG weapons, specifically focusing on the energy storage capabilities of different spring types and the implications for projectile design and safety compliance at events.
  • Matt expresses interest in creating a ranged weapon using a metal spring instead of a wooden bow, questioning the viability of this idea and the energy calculations he performed.
  • Some participants suggest starting with the desired projectile speed and weight to determine the necessary energy using the kinetic energy equation.
  • Concerns are raised about the stability of foam discs as projectiles, noting that they require spinning for stable flight, which complicates the launch mechanism.
  • Matt emphasizes the need to demonstrate that the metal spring can mechanically replicate the performance of a wooden bow that draws 30lbs at 28 inches for safety compliance at events.
  • One participant corrects Matt's energy calculation, suggesting a different spring constant and energy value, while also noting that reducing the pulling distance of the spring increases its stiffness.
  • Alternative projectile ideas are briefly mentioned, including mini frisbees and soft throwing stars.
The discussion contains multiple competing views regarding the calculations and feasibility of using a metal spring, with no consensus reached on the correct spring constant or energy values. Participants also disagree on the best approach to ensure projectile stability and safety compliance.
Participants express uncertainty about the assumptions made in energy calculations and the implications of using different spring types. The discussion highlights the complexity of balancing spring characteristics with projectile design and safety requirements.
Individuals interested in DIY weapon construction for RPG events, those exploring the mechanics of springs and projectiles, and participants in safety compliance discussions for similar activities may find this thread useful.
Matt_741
Hi there I'm Matt and I am a geek.
I love the RPG scene and intend on going to an event held in Derby but, for reasons of personal torment, I want to make the relevant equipment myself. In this case 1 sword two . . . well . . . let's say "ranged" weapons for now.
The foam sword needed wasn't hard LD45 plastazote foam + 1m carbon fiber tube + dyed latex = done.
Then I got a bit cocky and out of my depth with springs. Basically I know in events people use a bow (30lbs draw at 28") and arrow (with the head being a big lump of foam for obvious safety reasons) but that got me to wondering why not make something new? I'd already done so with the sword being a flammard to the traditional straight longsword affair. I looked at repeating crossbows and so on but the problem in this case was more with the arrows as, to make them safe, they had lost all of their aerodynamic capabilities. So I came up with the idea to have discs of foam fired by a launcher where the wooden leaf spring is replaced with a smaller metal one.
This is where my ignorance starts to jump up and down waving flags as it goes. I tried to work out the amount of energy stored in the wooden bow by taking the draw length of 0.7112m (converted into m from 28") the draw weight of 13.6077711kg (as the force of 30lbs converted into kg) and by using the equation E=half the spring constant (which I got as 19.13 N/m) times the change of distance squared I only got 4.84 Joules? Is that right?
If so can I just work out from there any spring (or combination of) that holds the same amount of energy and use that instead of a bow? Not to even get involved with the fun of seeing how the weight and shape difference of the projectile will affect it's flight. Or a firing mechanism. Or my ultimate hope that I could preload 6 such springs so I could fire off several shots before reloading.
But first things first.
Is my idea of using a metal spring which can store the same energy as a wooden spring viable?
Is that amount of energy that I worked out correct? If not please baby step me through all which is wrong. It's the only way I'll learn.
To finish will the use of a metal spring really reduce the size of the wooden bow down as much as I think? I mean I'm looking for a reduction of something almost the height of a person down to a mechanism that could fit on a forearm. Am I asking too much?
Any input greatly appreciated.
Matt.
Wouldn't it be easier to start with determining how fast you want your projectile to travel and how much it weighs? You can then plug those values into the kinetic energy equation (Ek = 1/2mv2)and thereby arrive at a figure which is suitable for your specific applicatiion.
The problem with a disc is that its inherently unstable unless its spinning. The faster it spins the more stable and level flight.
This is your key problem to overcome with any launch mechanism.
The only thing that comes to mind that would still be accurate is a lever arm.
You see the major point is, from the point of view of the safety check performed at these events, I need to prove that the spring (or springs) I use can be proven to be a mechanical equivalent of a wooden bow which draws 30lbs at 28". It must conform to that primarily. The issues of any projectile I use and it's relative shape or weight are irrelevant at this time. otherwise some gentle person with an experience of just working off of no mechanical guideline apart from "30 lbs at 28 inches" will just refuse any device built. I appreciate info on the projectiles but, right now, it is not the concern. It is the spring I, mentally speaking, need to get to grips with.
I might suggest Hooke's law:
http://en.wikipedia.org/wiki/Hooke's_law
mini frisbee's ?
soft throwing/ninja stars ??
something like oddjob's hat in the bond films ??
That spring constant is wrong. Your force is already 13*g = 130N at .7 m so your spring constant is around 190N/m and the stored Energy at 48 Joules. You can reduce the size with springs, but if you reduce the "pulling distance" the the needed spring gets very stiff very fast. Additionally you run into problems with soft projectiles, because the stronger the spring the more they squeeze instead of accelerating.
  • · Replies 42 ·
  • · Replies 40 ·
48K
11K
