| Thread Closed |
Why does hot air really go up? |
Share Thread | Thread Tools |
| Aug18-09, 04:49 PM | #1 |
I know a hot air balloon goes up because the density of the hot air inside is lower. But what about free air, not trapped in a balloon?
You often see exactly the same explanation, hot air is less dense so it goes up, but this does not make any sense if you consider the fact that air is just a bunch of molecules flying around freely and bouncing into each other a lot, and temperature is a measure of their average momentum. There's no such thing as a "pocket" of hot air that somehow pushes other air away while going up. All you can say is that in a certain area the average speed of the air molecules is higher. So why would this cause the air to rise, to such an extent that it even draws surface winds that fill the gap? I mean, the effect is real, gliders use it all the time, but what is really going on on a molecular level? The faster molecules should surely be pushing in all directions, not just up? I would expect them to transfer their excess energy to nearby molecules through collisions until an equilibrium is reached, but can't imagine why a whole "pocket" of air would tend to rise and leave a low pressure underneath, even drawing in surrounding air instead of pushing it away. |
| Aug18-09, 04:55 PM | #2 |
Admin
| Aug18-09, 04:55 PM | #3 |
Cool air is dense and tends to fall in the presence of warmer air, while warmer air is less dense, and it is displaced upward by the cooler air. None of this happens in isolation, of course, and the dynamics of air movement due to heating and cooling effects make predicting weather tough because modeling it is complex.
A good example of the dynamics is the cooling provided by onshore breezes along the coast. Today, it was over 90 deg F inland in Maine, while it was in the 70s in Rockland, on the coast. The reason? Solar heating over land made the air less dense, and the cooler, denser air from over the Atlantic moved in to displace it. |
| Aug18-09, 04:57 PM | #4 |
Remove the earth and leave just the hot and cold air behind - which way is up and which way is down? From this, you could probably say it has something to do with gravity (I might be wrong).
| Aug18-09, 04:57 PM | #5 |
| Aug18-09, 04:58 PM | #6 |
| Aug18-09, 05:04 PM | #7 |
| Aug18-09, 05:09 PM | #8 |
That was the whole point of my question, but you don't seem to have taken the time to really understand what I was asking. |
| Aug18-09, 05:09 PM | #9 |
Mentor
| Aug18-09, 05:11 PM | #10 |
Mentor
| Aug18-09, 05:11 PM | #11 |
It is NOT a continuous fluid, even though that coincidentally happens to be a pretty good approximation for a lot of problems. I want to know what really happens if you consider air molecules to be billiard balls. |
| Aug18-09, 05:13 PM | #12 |
Recognitions:
| Aug18-09, 05:15 PM | #13 |
Admin
| Aug18-09, 05:15 PM | #14 |
Mentor
| Aug18-09, 05:19 PM | #15 |
Mentor
| Aug18-09, 05:20 PM | #16 |
| Aug18-09, 05:24 PM | #17 |
Mentor
Also, look into the concept of diffusion:
The word "gradual" means it takes some time. How much time? Well it turns out that the rate of diffusion depends on the starting conditions, but the size of the masses of air are not part of those conditions. Ie, the boundary will diffuse at a certain rate (in cm per minute or some similar metric) if the two volumes are 1 cubic meter or 1 cubic kilometer. |
| Thread Closed |
| Thread Tools | |
