Efficient Purging of Air from Hydrogen-based Model Car System"
  • Thread starter Thread starter ChaoticLlama
    Air System
The discussion revolves around the challenges of purging air from a hydrogen-based model car system without allowing hydrogen emissions into the environment. Participants explore various methods to achieve an effective purging process while maintaining system performance.
  • One participant describes the current purging method, which involves producing hydrogen gas to displace air but results in hydrogen venting to the environment.
  • Another participant suggests purging with nitrogen or helium to eliminate oxygen, but raises the concern of these gases acting as diluents in the closed-loop system.
  • A participant acknowledges the issue of diluents affecting cell performance and notes that pressure build-up is minimal in their system.
  • One suggestion involves using a 'hydrogen trap' or purging into a storage container to prevent venting hydrogen to the atmosphere.
  • Another participant proposes the idea of vacuum pumping the tubing to eliminate air before introducing inert gas and pumping again.
Participants express multiple competing views on how to effectively purge the system without hydrogen emissions, and the discussion remains unresolved regarding the best approach.
Participants have not reached a consensus on the most effective purging method, and there are unresolved considerations regarding the impact of inert gases on system performance.
ChaoticLlama
Here is the situation:
We are building a small model car (roughly 8 in wide by 18 in long) whereby hydrogen is produced in a chemical reaction, travels through some tubing to our fuel cells, which in turn powers the motor.
The issue lies in the start-up procedure; it is required to purge air from the tubing system so as to not dilute the hydrogen within the system.
Here is how we are purging the system currently:
We begin the reaction, producing hydrogen gas which removes any air present in the tubing, venting to the environment. After the short purge period, the outlets are closed off, and the car proceeds.
The problem is, we require no hydrogen emissions to the environment during the purge.
Is there any way to accomplish this?
Thank you.
P.S., please let me know if this description is unclear, I can provide diagrams and/or pictures as required.
Hi Chaotic. Normally such systems are purged with nitrogen or helium prior to initiating hydrogen flow. That way there's no oxygen. It also eliminates the possibility of hydrogen being vented to atmosphere, but here's the catch. Now there's nitrogen or helium in your system. Is that ok?
Yes, that is a catch indeed.
The tube system will be a closed loop, and therefore the nitrogen or helium would act as diluents; reducing the performance of the cell.
FYI: The pressure build-up is very small, so that is not a concern. There is a gauge which reads from 0 to 5 psig, and the needle as never been observed to move.
Thanks for taking time to read this.
Could you perhaps insert some sort of 'hydrogen trap' in your purge port? (Chilled magnesium, maybe?) Or, even simpler, purge the line into a storage container such as a balloon that won't let it vent to atmosphere?
How about just pumping down the tubing first?
Yes, as mentioned by berkman, systems can also be vacuum pumped to eliminate air. Generally, this is followed up by breaking vacuum with an inert gas (nitrogen and helium) and then pumping again.
  • · Replies 21 ·
32K
  • · Replies 27 ·
11K
