What Is the Spring Constant of the Second Spring in a Dual-Support System?
  • Thread starter Thread starter dance_sg
The discussion focuses on calculating the spring constant of the second spring in a dual-support system involving a 7.50-kg ball. The first spring has a spring constant of 475 N/m and an initial length of 35.0 cm. When the ball reaches equilibrium at a height of 20.0 cm, the second spring, which has an initial length of 25.0 cm, must be analyzed to determine its spring constant. The solution involves applying the force balance equation, where the force exerted by the second spring equals the gravitational force minus the force from the first spring.
  • Understanding of Hooke's Law (f = kx)
  • Basic knowledge of gravitational force calculations
  • Familiarity with equilibrium concepts in physics
  • Ability to manipulate and solve algebraic equations
  • Calculate the gravitational force acting on the 7.50-kg ball using F = mg.
  • Determine the displacement of the second spring when the ball is at equilibrium.
  • Apply the force balance equation to find the spring constant of the second spring.
  • Review related concepts in dual-spring systems and their applications in physics.
Students studying mechanics, particularly those focusing on spring systems and equilibrium, as well as educators looking for practical examples of applying Hooke's Law in problem-solving scenarios.
dance_sg
A 7.50-kg ball is placed on top of a spring with a spring constant of 475 N/m that has an initial length of 35.0 cm (h1). When the ball has reached its equilibrium position, it is supported by both springs at a height of 20.0 cm above the table (h3). If the shorter spring has an initial length of 25.0 cm, what is its spring constant?
f=kx ---->attached is the makeshift drawing i made to resemble the actual diagram since it was to big.
this is what my teacher has told me to do : The magnitude of the force exerted by the second spring is equal to the gravitational force minus the force the first spring exerts on the mass. Divide the force the second spring exerts on the mass by the displacement of that spring when the ball is at equilibrium position to find the spring constant for the second spring.
so i have to find the force of both springs whcih i can do for the first one by multiplying 475n/m by 0.35m. how do i find the force of the second one tho?
sorry. here is the diagram
  • · Replies 31 ·
