How do you use a Rotation Matrix in 2-D?
The discussion revolves around the application of a 2D Rotation Matrix, particularly in scenarios where the vector is not positioned at the origin. Participants are exploring how to determine the new coordinates of a vector's endpoint after rotation, given its initial position and the angle of rotation.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants are questioning how to interpret the input and output of the rotation matrix, specifically whether to use coordinates or components. There is also discussion on the process of translating a vector to the origin for rotation and then translating it back.
Some participants have offered guidance on moving the vector to the origin for rotation and then returning it to its original position. Others have shared their own formulations and approaches to the problem, indicating a collaborative exploration of the topic without reaching a definitive consensus.
There is an ongoing discussion about the definitions and interpretations of the components and coordinates involved in the rotation process, as well as the implications of the vector's initial position not being at the origin.
Saladsamurai
I am having some trouble deciphering what the input and output of a 2D Rotation Matrix actually represent.
All example online have the vectors oriented at the origin. I know you can move them anywhere so long as you maintain their length and orientation, but here is my question:
Let's say I have a vector that is not located at the origin. Call its initial point (x0, y0) and its terminal point (x1, y1)
Now let's say that it has rotated through the positive angle of Phi. It's initial point is clearly still (x0, y0) and its new terminal point is (x2, y2).
Using only (x0, y0) and angle Phi, how can I find the coordinate (x0, y0) ?
I know that the Rotation Vector is defined as:
My issue is that since they chose the origin, x1 and y1 in their example could be either the coordinates OR the components.
So, for the general 2D case: Do I plug in the coordiantes or components? And are the results the coordinates or components?
I am under the impression that it is the latter in both cases. And so in order to obtain the actual coordinates of my new vectors endpoint, I must add the resulting components to the initial coordinate (x0, y0)
Does that sound right?
Well, you can move it to the origin, rotate it, and move it back.
So if v = (x0, y0) and w = (x1, y1), then: a) calculate w - v; b) apply the rotation matrix to obtain a new vector z; c) calculate z + v.
If the tail of the vector r that you want to rotate is not at the origin, then find the position vector R of the tail with respect to the arbitrary origin and use the matrix to rotate the sum R+r. The result will be the coordinates of the tip of rotated vector r. To find the coordinates of the rotated tail, use the matrix once more on R.
I just wrote a code to test a few cases of what I said in the OP, and this is the formula I came up with. I think it is consistent with what you guys are saying:
r_x = x1 - x0
r_y = y1 - y0
x2 = x0 + (r_x * Cos(theta) - r_y * Sin(theta))
y2 = y0 + (r_y * Cos(theta) + r_x * Sin(theta))
  • · Replies 18 ·
