Integrating (x^2-1)^n: How to Get to the Answer?
  • Thread starter Thread starter raul_l
    Integrate
The discussion revolves around the integral of the expression \(\int^{1}_{-1} (x^2-1)^n dx\), with the original poster attempting to derive a specific result related to orthogonality of associated Legendre functions.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • The original poster explores integration by parts and substitution methods, expressing uncertainty about the complexity of the integrand. They also mention trying the binomial expansion and question how to simplify the resulting series. Other participants suggest using trigonometric identities and reduction formulas to approach the integral.
Participants are actively sharing various methods and insights, with some guidance provided on using binomial expansion and trigonometric identities. There is an ongoing exploration of different approaches without a clear consensus on the best path forward.
The original poster notes a reference to a book that contains much of the derivation but expresses confusion about the final steps. There is an implication of imposed homework constraints, as the discussion is framed within a homework help context.
raul_l
The whole expression is
[tex]\frac{(-1)^n (2n)!}{2^{2n} (n!)^2} \int^{1}_{-1} (x^2-1)^n dx[/tex]
and the answer should be
[tex]\frac{2}{2n+1}[/tex]
but I don't know how to get there.
I came across this while checking the orthogonality of the associated Legendre functions.
First I tried integrating by parts.
[tex]\int^{1}_{-1} (x^2-1)^n dx = \int^{1}_{-1} (x^2-1)^{n-1} (x^2-1) dx =[/tex]
[tex]= [(x^2-1)^{n-1} (x^3/3-x)]^{1}_{-1} - 2(n-1) \int^{1}_{-1} (x^2-1)^{n-2} x(x^3/3-x) dx =[/tex]
[tex]= - 2(n-1) \int^{1}_{-1} (x^2-1)^{n-2} x(x^3/3-x) dx[/tex]
I think that by integrating by parts I would eventually get rid of n under the integral sign which is good but the integrand itself gets more and more complicated so I'm not sure whether I should continue doing this.
Then I tried making the substitution [tex]x \rightarrow cos(x)[/tex]
[tex]\int^{1}_{-1} (x^2-1)^n dx = - \int^{0}_{\pi} (cos^2 (x)-1)^{n} sin(x) dx =[/tex]
[tex]= \int^{\pi}_{0} (-1)^n sin^2 (x)^{2n-1} dx[/tex]
and again, I'm not sure whether that will lead me anywhere or not.
And guidance would be appreciated.
Try the binomial expansion of [itex](x^2-1)^n[/itex] and exploit the fact that the interval of integration is [-1, 1]. Hint: even vs. odd terms. See if that gets anywhere.
--Elucidus
Yes, I forgot to mention earlier that I had also tried the binomial formula.
[tex]\int^{1}_{-1} (x^2-1)^n dx = \int^{1}_{-1} \sum^n_{k=0} \frac{n!}{k!(n-k)!} x^{2n-2k} (-1)^k dx = \sum^n_{k=0} \frac{(-1)^k n!}{k!(n-k)!} \int^{1}_{-1} x^{2n-2k} dx = \sum^n_{k=0} \frac{(-1)^k n!}{k!(n-k)!} \frac{2}{2n-2k+1}[/tex]
So far the expression has become
[tex]\frac{(-1)^n (2n)!}{2^{2n} (n!)^2} \sum^n_{k=0} \frac{(-1)^k n!}{k!(n-k)!} \frac{2}{2n-2k+1}[/tex]
which has to be equal to [tex]\frac{2}{2n+1}[/tex]
I still don't understand how.
Perhaps there are some formulas that could be used but I'm unaware of.
Most of the derivation is given in this book: http://physics.bgu.ac.il/~gedalin/Teaching/Mater/mmp.pdf
I understand all of it except the very end (page 311).
Okay, I can use
[tex]\int sin^n (x) dx = -\frac{1}{n}sin^{n-1}(x) cos (x) + \frac{n-1}{n} \int sin^{n-2}(x)dx[/tex]
which in my case becomes
[tex]\int^{\pi}_0 sin^n (x) dx = \frac{n-1}{n} \int^{\pi}_0 sin^{n-2}(x)dx[/tex]
Now
[tex]\frac{(-1)^n (2n)!}{2^{2n} (n!)^2} \int^{\pi}_{0} (-1)^n sin^{2n+1}(x) dx =[/tex]
[tex]= \frac{(2n)!}{2^{2n} (n!)^2} \frac{2n}{2n+1} \int^{\pi}_{0} sin^{2n-1}(x) dx =[/tex]
[tex]= \frac{(2n)!}{2^{2n} (n!)^2} \frac{2n(2n-2)}{(2n+1)(2n-1)} \int^{\pi}_{0} sin^{2n-3}(x) dx =[/tex]
[tex]= \frac{(2n)!}{2^{2n} (n!)^2} \frac{2n(2n-2)...(2n-2n+2)}{(2n+1)(2n-1)...(2n-2n+1)} \int^{\pi}_{0} sin(x) dx =[/tex]
[tex]= \frac{(2n)!}{2^{2n} (n!)^2} \frac{2^n n(n-1)...1}{(2n+1)(2n-1)...(2n-2n+1)} 2 =[/tex]
[tex]= \frac{(2n)!n!}{2^n (n!)^2} 2 \frac{2n(2n-2)...2}{(2n+1)2n(2n-1)...1} =[/tex]
[tex]= \frac{(2n)!}{2^n n!} 2 \frac{2^n n(n-1)...1}{(2n+1)!} =[/tex]
[tex]= \frac{2}{2n+1}[/tex]
Problem solved. Thank you.
  • · Replies 105 ·
13K
