Heating water in a sealed bottle
  • Context: Undergrad
  • Thread starter Thread starter redargon
    Heating Water
The discussion revolves around the relationship between the pressure in a sealed bottle of water and the temperature of the water when heated in a microwave. Participants explore the effects of headspace, the volume of water, and the behavior of gases and vapors under changing temperatures.
  • One participant questions how to determine the pressure in the bottle as it relates to the temperature of the water, particularly considering the headspace of air and its volume.
  • Another participant suggests that if the headspace and amount of water are sufficiently large, the volume of headspace may not significantly influence the pressure, but warns about the potential for all water to vaporize.
  • A different participant emphasizes that the dilatation of water could cause the pressure to increase more rapidly with temperature.
  • One participant proposes using the ideal gas law to calculate the pressure of the air in the headspace and suggests using steam tables to find the vapor pressure of water at specific temperatures.
  • Another participant expresses confusion about which density to use for the ideal gas law calculations, considering different conditions of air density.
  • One participant mentions the possibility of using the relationship P1/T1 = P2/T2 to relate pressures and temperatures, assuming constant volume and mass in the sealed bottle.
  • Another participant argues that the headspace air plays a significant role, presenting two scenarios: one with little air and one with little water, discussing how each affects pressure differently.
Participants express differing views on the influence of headspace volume on pressure, with some arguing it is negligible while others believe it has a significant impact. The discussion remains unresolved regarding the exact relationship between water volume, headspace, and pressure changes.
Participants reference the ideal gas law and steam tables, indicating a reliance on specific conditions and assumptions that may not be universally applicable. There is also mention of potential confusion regarding the correct application of gas laws and densities.
redargon
Say I want to put a bottle of water in the microwave and heat it up. How do I determine the pressure in the bottle as a relation to the temperature of the water? Assuming that there is a headspace of air between the liquid and the bottle cap. Is it dependent on the volume of the air space? ie. would a half filled bottle experince a greater pressure at the same temperature than a bottle that is 90% filled?
I'm trying to use partial pressures, but I'm battling to find out how much of the water is turned into vapour at certain temperatures.
Science news on Phys.org
As long as the headspace is large enough,
as long as the amount of water is large enough,
the amount of headpace will not influence the pressure​
otherwise
all the water could be varporised​
otherwise
the the dilatation of water could make the pressure increase much faster with temperature​
end
otherwise
otherwise
end
ummm... I said a bottle of water in a microwave. Think, standard sealed bottle of water. The rest of your post wasn't helpful, but thanks anyway.
Boiling steam at atmospheric pressure has a partial pressure equal to atmospheric pressure. Use the ideal gas law to calculate the pressure of the air and add the two together. lalbatros is right that the volume of air is irrelevant...unless you intend to heat it past boiling, which I wouldn't recommend. But you can find the associated pressure with a steam table: http://www.efunda.com/materials/water/steamtable_sat.cfm
So I found out that the vapour pressure of water is about 0.198bar at 60°C (using steam tables as suggested). Now what density do I use for the ideal gas law for calculating the pressure of the air? 1.28kg/m³ (STP) or the value for air at 60°C or the density of the air/water avpour mixture. I'm running myself in circles here because I can't frikkin remember my basic chem... :(
Also, if I'm using ideal gas laws, couldn't I just use P1/T1=P2/T2. As in, the pressure of gas in the volume of the sealed bottle is atmospheric at 21°C, I stick it in the microwave and the temperature rises to 60°C, so the pressure rises accordingly.
d'oh. if the volume and the mass stay the same (as they are in the closed bottle), then the density must be constant. Sorry, I think I had a brain fart there.
Id say that the headspace air does quite a lot.
Consider two cases
One where there is very little air in the bottle. Heating it in the microwave will dilate the water the bottle and the air. Assuming the bottle dilates less then water then pressure will go up and it will compress the air some, plus the dilation of the air.
And one where the there is very little water. So dilation of the water adds very little to bottle pressure but the heating of the air ( by contact to the water or anyway) will be the sole significant contributor.
I'm sure that 1 cm3 of extra air in the headspace doesn't do much but it will be different.
quote from Goldmember: Fat Bastard: "Let's all take o whiff o that" :))
  • · Replies 29 ·
