Electric field of two polar molecules
The discussion revolves around the relationship between the dipole moment and the electric field generated by two polar molecules. Participants explore concepts related to van der Waals forces, dipole-dipole interactions, and the effects of external electric fields on dipole moments.
  • One participant questions why the dipole moment does not depend on the electric field from the dipoles.
  • Another participant seeks clarification on the relationship between van der Waals forces and dipole-dipole attraction.
  • Some participants propose that van der Waals forces arise from induced polarization between nearby molecules, while others express uncertainty about the relationship between dipole moments and electric fields.
  • A participant explains that the dipole moment describes the torque caused by an external electric field, suggesting it is independent of the electric field produced by the dipole itself.
  • There is a discussion about whether the fields from two equal charges would cancel each other out, with differing opinions on this point.
  • One participant mentions that the electric field from a dipole drops off more quickly than that from a point charge and depends on the dipole moment, orientation, and distance.
  • Another participant expresses confusion about the overall topic, questioning if the discussion pertains to molecular polarity.
Participants do not reach a consensus on the relationship between dipole moments and electric fields, with multiple competing views and ongoing uncertainty regarding the nature of interactions between polar molecules.
Some participants reference the mathematical descriptions of electric fields and dipole moments, but there are unresolved assumptions and dependencies on definitions that remain unclear.
enkar
Why is it that for the case of two polar molecules the dipole moment does not depend on the electric field from the dipoles?
Please be more specific.
Here is the question: Find the dependence of the van der Waals force on separation distance between two polar molecules.
Aren't Van der Waals force and dipole-dipole attraction two different things?
As I understand it (which is actually not very much), they are the same. More specifically, the Van der Waals force arises when the electron cloud of one atom/molecule induces a significant polarization on the nearby atoms/molecules and causes a chain reaction. I was not aware of the Van der Waals force between molecules that already have a dipole moment, but I suppose it is the same principle of attraction.
enkar,
regarding your original question, I don't know. I would be surprised to hear affirmation of this from an official source. I also think that the dipole moment and electric field should be related, so we are in the same boat with this question.
Well, it turns out that the dipole moment does not depend on the electric field. But I don't know why. That's what I'm trying to get here.
The dipole moment is used to describe how much of a torque an EXTERNAL electric field causes. It has nothing to do with the electric field of the charges that make the dipole moment.
But wouldn't a field be induced at the other molecule by the polarity of the first?
Given two charges, +Q and -Q, separated by a displacement vector [itex]\vec d[/itex]pointing from the negative charge to the positive charge, the dipole moment is defined by [itex]\vec p = Q\vec d[/itex]. It is a quantity that describes the geometry of the arrangement of the two charges.
The molecules have equal charges. Would the fields effectively cancel each other resulting in no net effect?
I don't think so. From what I remember, the field of a charge distribution expands readily into a double infinite series of products of Legendre polynomials and spherical harmonics. For the dipole field, the zeroth order term vanishes, but the first order term is nontrivial. Unfortunately, I've trashed my EM notes (an an emotionally dominated decision), but I'm sure someone here has the expression (or is willing to sit and derive it). I still don't understand how the electric field from a dipole can be independent of the dipole moment. From the expansion, it directly depends on the charge and characteristic distance.
To me at least, what happens between the charges that make up the dipole system is completely irrelevant in terms of what the dipole moment is for. You consider only the effects of external fields.
polar molecules
I'm still unclear as to your actual question. Are you asking:
(1) about the dipole moment? If so, as has been explained, that is a description of the charge separation of the molecule. The dipole moment will determine the effect that an external field will have on the molecule.
(2) about the electric field of a dipole? If so, realize that since there's a plus and minus charge close to each other, the field will drop off much more quickly than the field from a point charge. The field depends on: the dipole moment, the orientation with respect to the polar axis, and distance. For large distances, the field drops off as [itex]1/r^3[/itex].
(3) about the dipole-dipole interaction? If so, then realize that this is a fairly weak force (compared to an ionic bond, for example). But no, the fields don't "cancel". Realize that given the opportunity, the polar molecules will arrange themselves so that the + side of one will be closer to the - side of the other, creating the so-called dipole-dipole attraction.
I'm lost overall about what the discussion is about, are u talking about the polarity of molecules?
  • · Replies 22 ·
  • · Replies 21 ·
