Best Spur Gears for Ratio .31 under .5" Width, 2.4" OD
  • Thread starter Thread starter SlimJ87D
    Gear
The discussion centers around finding suitable spur gears that meet specific design criteria, including a gear ratio of .31, a maximum width of .5 inches, and an outside diameter not exceeding 2.4 inches. The materials specified for the gears are steel, and the application involves a mechanical design intended to withstand a load of 300 lbs.
  • Experimental/applied
  • One participant notes that McMaster Carr's gears are too wide for their design, specifically exceeding 1 inch in width.
  • Another participant suggests checking Boston Gear for a variety of spur gears, although they express uncertainty about current offerings.
  • A third participant recommends Stock Drive Products, providing a link to their website, and expresses enthusiasm about their selection.
  • The original poster mentions the need to calculate gear failure under a load of 300 lbs for a vice designed to break small metal samples.
Participants do not appear to reach a consensus on a specific supplier or solution, as multiple suggestions are made without agreement on the best option. The discussion remains open-ended with various recommendations and considerations presented.
Participants have not provided detailed specifications for the gear design beyond the stated dimensions and material requirements. There is also no discussion of the specific mechanical properties or calculations related to gear failure.
SlimJ87D
Mcmaster carr's gears are a bit too wide for my design.
I need a pair of gears to have a ratio of .31, that is around .7" to 2.38"
The widths for the gears can not be any larger than .5" and ideally even less, at Mcmaster Carr they are about 1"
Have to be made of steel.
Cannot be any larger than 2.4" outside diameter.
Boston Gear used to offer a variety of spur gears. Not sure now, but might be worth checking.
Give Stock Drive Products a try.
http://www.sdp-si.com/index.asp
Wow, thank you very much man, they have a very nice wide selection that I have never seen before. I'm sure I will find it here.
Now to just calculate the failure because I need my gears to survive a simple load of 300lbs. I am building a type of vice to break small samples of metal, quite opposite of what a vice does.
18K
11K
  • · Replies 48 ·
23K
  • · Replies 52 ·
9K
