What is the Impact of an Apple Falling on My Head?
The discussion revolves around the physical principles involved when an apple falls and impacts a person's head, exploring concepts such as force, impulse, and the conditions affecting the resulting pain. Participants examine both simple and complex scenarios, including comparisons of static and dynamic forces, and the implications of different impact conditions.
  • One participant suggests that the physical value causing pain from an apple falling is impulse.
  • Another participant introduces a more complex scenario involving a concrete block and questions the height required for an object to cause damage based on its weight.
  • Several participants discuss the relationship between force, mass, and acceleration, emphasizing that the force experienced during impact is influenced by the deceleration of the falling object.
  • There is a debate about whether impulse or force is the primary factor causing pain, with some arguing that impulse accounts for the time over which the force acts.
  • A participant raises the question of whether accurate calculations of impact forces can be made or if empirical testing is necessary, noting the complexities involved in collisions.
  • Another participant discusses the pressure created upon impact and relates it to Newton's laws, suggesting that the pain felt is proportional to the pressure exerted by the falling apple.
  • One participant expresses confusion over the discussion, questioning if impulse is indeed the correct explanation for the pain caused by the apple's impact.
  • Responses clarify that while impulse is a more comprehensive concept, force is still a critical factor in the sensation of pain.
Participants do not reach a consensus on whether impulse or force is the definitive explanation for the pain caused by the falling apple. Multiple competing views remain regarding the relationship between these concepts and their implications in different scenarios.
The discussion includes various assumptions about the conditions of impact, such as the elasticity of the head and the specifics of the falling object's properties. There are unresolved mathematical steps and dependencies on definitions that influence the arguments presented.
archis
If a apple falls on my head, what is the physical value that makes my head hurt?
If the question is that simple, then the answer is simpler :D
ANSWER IS: IMPULSE
want more details? ask, hehehehe. And please set some good title for the topic next time.
bye
OK, ill make it little bit difficult.
Lets say a concrete block holds an element that has a weight of 100 kN. The block cracks, is destroyed if the weight is 200kN. So from what height should the element fall to destroy the concrete block? I want to compere the stress done by the element to the block if it just stands there and if it is in motion.
The force of the impact (impulse) on your head is equal to the mass of the apple multiplied by the rate of change of velocity of the apple with respect to time.
Force=MA
Impulse=Int F dt
KE doesn't hurt no matter how much it has. Force is what makes it hurt, which is determined by acceleration.
''Force is what makes it hurt, which is determined''
So why the apple standing still on my head doesn't hurt, but falling from tree does. Apple produces force F=mg, does it get bigger if it falls? think not. How to compere stress done to my head between these two apple conditions?
Because the apple sitting on your head isn't experiencing a decelleration. The decelleration of an apple falling onto your head (and being slowed down by your head) is what produces the force which you feel.
mg is the applies weight.
The force it makes is F=MA.
Where A is (vmax-vmin/time).
So for example. let's say the apple weighs 1 Kg (its a bloody big apple). And it's traveling at 10m/s and stops in 1 second.
The force it applies to your head at contact is. 1(kg)*10(m/s^2)=10N.
Lets say it stops in 0.1 of a second.
the acceleration is now 100m/s/s so the force is now 100N.EDIT: So there's no confusion when I say acceleration that includes deceleration, but there is little point makign any distinction as they are both the same thing.
Thank you xxChrissxx now it makes sence. So to know how big will be the force i need to know how much the impact would take time? And the time of the process is dependent from the elasticity of my head? Am i thinking right? Now it makes sense to put a pillow on my head.
Thats spot on archis.
If the A hits B is it possible to calculate accurate this force (see post #3) or only tests and experiments could give a accurate result?
Well strictly it can only be done empirically, as collisions are generally very complex and no two collions are ever precisely thae same. It depends on how the bricks are orientated, how they strike the ground. What the two materials are made of, what happends during the impact event. etc etc.
However with some simple assumptions and some information on the impact, you'll have to make an educated stab at guessing the impact time you can work out the drop height to attain a force necessary to break something.
Suppose you are standing on planet Earth now the apple is falling down on your head freely. Then its force should be F = mg OR GMm/(r - h)2
where, m = mass of apple
M = mass of Earth
r = distance of apple from Earth
h = your height
when this apple will fall on the surface of head it would create pressure.
P = F / A
as much pressure it would create that much pain you would get.
You have already taken revenge of this pain according to NEWTONS LAW by creating same but opposite force. F = - mg
so the apple can be smashed
The force upon collision isn't the same as when it is standing still. When something picks up speed and collides into something, there will be a transfer of energy resulting in a large momentary jump in the force, which can be described by the impulse - the impulse is the change in momentum, or for that matter, the distribution of momentum across the interacting objects - it can also describe the "distribution" of force through time.
I've left this thread for two days, now I come back to see that my reason is wrong? are you guys saying that it's not "IMPULSE" that's causing the hurt?
Should I remind you people that the definition of impulse is "the change in momentum through time" which means the change in velocity. The apply hurts him because it's decelerating, i.e. it's because the impulse his head is applying on the apple!
Impulse also explains why if a fast car hits a wall the damage is more than a slow car hitting the wall, it's because the impulse the wall applies on the latter is less!
am I saying wrong?!
Dont panic impluse is the same thing. Impulse is acutally more correct as it takes into account the distrubution over time.
impulse = f * t
The method we used assumes an average force, but is a more simple explinations as it doesn't require calculus. Its still the force that does the hurting, impulse describes how the force acts better.
Eg. When we say that its force, we acutally mean impulse. But for someone who is unfamiliar with the concepts this caould be confusing. because what we are waying is tha tthe force is acting over the impact time.
Apple 1 KG, stops from 10m/s in 1 S.
Force = 10N
The impluse applied is 10(n) for 1(s) = 10NsUsing the rate of change of mumentum and time, we will still get a 10Ns impulse, but your method will describe the curve of how the force acts. The area unde rthe force-time curve will be the same in both incidences. So for example it would start and end at zero, curve and peak at 20N
Actually my answer was for what he's asked! He asked "what's the physical quantity that causes the pain", well, the answer is impulse!
Your last post now solved the problem, because he's ought to understand it's eventually called impulse :)
Ciao
by the way, I like that expression "panic" of yours :P
  • · Replies 18 ·
  • · Replies 46 ·
