Vibrations & Waves: Solving Mass, Spring Constant & Energy
  • Thread starter Thread starter Elvis
    Vibrations Waves
The discussion focuses on solving problems related to vibrations and waves involving a mass-spring system. The first problem calculates the total energy of a 5 kg mass attached to a spring with a spring constant of 13 N/cm, yielding a total energy of 26 Joules. The second problem involves a 15 kg mass and a spring constant of 20 N/cm, where the user seeks to determine the speed of the mass at a position of 5 cm. The correct approach involves using the equation E = PE + KE, where potential energy (PE) and kinetic energy (KE) are calculated based on the spring's characteristics and the mass's position.
  • Understanding of Hooke's Law and spring constants
  • Knowledge of potential energy (PE) and kinetic energy (KE) formulas
  • Familiarity with mass-spring systems in physics
  • Ability to manipulate equations involving energy conservation
  • Learn how to apply Hooke's Law in various scenarios
  • Study the principles of energy conservation in mechanical systems
  • Explore the relationship between amplitude, position, and energy in oscillatory motion
  • Investigate the effects of mass and spring constant on oscillation frequency
Students studying physics, particularly those focusing on mechanics, as well as educators and anyone interested in understanding mass-spring systems and energy calculations in oscillatory motion.
Elvis
Vibrations and waves
1) A 5 kg mass, m, rests on a frictionless, horizontal, wooden table top, and is attached to one end of a spring anchored at its other end . If the spring has a spring constant=13 N/cm and the mass is pulled back (in the positive direction ) 20 cm and released, to the nearest tenth of a joule, what is its total energy?
2) if the mass is 15 kg and the spring constant is 20 N/cm, to the nearest tenth of a m/s, what is its speed at x= 5 cm?
I have solved the 1st one :
1N/cm=100N/m
E = PE + KE
E = 1/2kA^2 + 1/2mv^2 At KE v=0 because the mass stops momentarily as it changes directions. Then :
E = PE
E = 1/2kA^2
E = 1/2(13*100)*(0.2)^2
E = 26J
I have problem with the second problem. please help to solve this. I have 2 hours that I am tryin to solve it . I have only the answer that is 2.2m/s.
Please help......
:cry:Lol...
Find the total energy, just like you did for part one. Then use:
Elvis said:
E = PE + KE
Solve for v, when x = 5 cm.
That equation should be: E = 1/2kx^2 + 1/2mv^2. Use x, not A (which usually stands for amplitude).
  • · Replies 17 ·
  • · Replies 21 ·
