Derivation of Doppler Shift from Frequency to Wavelenght
The discussion centers around deriving the Doppler shift equation from a frequency-based form to one expressed in terms of wavelength. The context involves wave mechanics, specifically the relationship between frequency and wavelength, and the effects of relative motion on observed wave properties.
  • Participants explore the relationship between frequency and wavelength, attempting substitutions and expansions. Some question the validity of algebraic manipulations, while others suggest using Taylor's expansion for small quantities. There is also discussion about the implications of small angles and the correct application of derivatives.
The discussion is active, with participants providing guidance on algebraic steps and Taylor expansions. There is a mix of interpretations and approaches being explored, with some participants expressing uncertainty about their methods and assumptions.
Participants note the assumption that the velocity of the source is much smaller than the velocity of the wave, which influences their mathematical approaches. There is also mention of potential confusion regarding the variables involved in the derivation.
IBY
Derive the doppler shift equation from the equation in terms of frequency to one in terms of wavelength. Clues: frequency=c/lamda, use Taylor's expansion, velocity of source is much smaller than velocity of wave.
c-velocity of wave
v-velocity of source
f-frequency
lambda-wavelength
Doppler shift in terms of frequency
[tex]f'=f(1+\frac{v}{c}cos \theta)[/tex]
Relationship between wavelength and frequency
[tex]\lambda=\frac{c}{f}[/tex]
Taylor's expansion
[tex]\sum_{n=0}^2 \frac{f'^n(f(1+\frac{v}{c}cos \theta)}{n!}x^n[/tex]
I used the wavelength-frequency relationship equation in order to substitue for f in the doppler frequency equation to get:
[tex]\frac{c}{\lambda'}=\frac{c}{\lambda}(1+\frac{v}{c}cos \theta)[/tex]
[tex]\frac{c}{\lambda'}=\frac{c}{\lambda}+\frac{c}{\lambda}\frac{v}{c}cos \theta[/tex]
[tex]\frac{c}{\lambda'}=\frac{c}{\lambda}+\frac{v}{\lambda}cos \theta[/tex]
[tex]\lambda'=\frac{c}{\frac{c}{\lambda}+\frac{v}{\lambda}cos \theta}[/tex]
[tex]\lambda'=\lambda+\frac{\lambda c}{v cos\theta}[/tex]
I used Taylor's expansion to the second degree, and I got:
[tex]\lambda'=\frac{\lambda c}{2v}x^2+{\lambda+\frac{\lambda c}{v}[/tex]
I small angle approximate, so x^2=sin^2 (theta), use trig id to get sin^2 (theta)=1-cos^2 (theta)
[tex]\lambda'=\frac{\lambda c}{2v}-\frac{\lambda c}{2v}cos^2 \theta+\lambda+\frac{\lambda c}{v}[/tex]
[tex]\lambda'=\frac{3\lambda c}{2v}-\frac{\lambda c}{2v}cos^2 \theta+\lambda[/tex]
And now, I am dead in the water.
You might want to double check this step:wink:
@gabbagabbahey
I don't see it. If one divides by fraction, aren't you supposed to multiply with the bottom part reciprocated?
[tex]\frac{A}{A+B}\neq1+\frac{A}{B}[/tex]
You can't divide up the denominator in this manner
If so, then I use Taylor's expansion on this?
[tex]\lambda'=\frac{\lambda c}{c+vcos \theta}[/tex]
I would divide both the denominator and numerator by [itex]c[/itex] first:
[tex]\lambda'=\frac{\lambda}{1+\frac{v}{c}\cos\theta}=\lambda\left(1+\frac{v}{c}\cos\theta\right)^{-1}[/tex]
The reason you want to do this is because you know [itex]v\ll c[/itex], so [itex]\frac{v}{c}\cos\theta[/itex] will be a small number and you are left trying to Taylor expand [itex](1+\text{small number})^{-1}[/itex] which you can do easily.
Okay, one last fact checking (hopefully) before I go away for good. :smile:
So there is:
[tex]\lambda(1+\frac{v}{c}cos \theta)^{-1}[/tex]
I derive it:
[tex]\lambda \frac{v}{c}sin \theta(1+\frac{v}{c}cos \theta)^{-2}x[/tex]
I do it again, use the multiplication rule:
[tex](\lambda (\frac{v}{c})^{2}sin^2 \theta(1+\frac{v}{c}cos \theta)^{-3}+\frac{\lambda \frac{v}{c}cos \theta(1+\frac{v}{c}cos \theta)^{-2}}{2})x^2[/tex]
Small number, so sin of theta is zero and cos of theta is 1, x=sin so including all of the equation above, I am left with:
[tex](\frac{\lambda \frac{v}{c}(1+\frac{v}{c})^{-2}}{2})sin^2 \theta+\lambda(1+\frac{v}{c})^{-1}[/tex]
Trig id sin^2 theta is 1-cos^2 theta
[tex](\frac{\lambda \frac{v}{c}(1+\frac{v}{c})^{-2}}{2})(1-cos^2 \theta)+\lambda(1+\frac{v}{c})^{-1}[/tex]
For some reason, I feel like I went into a dead end.
IBY said:
Okay, one last fact checking (hopefully) before I go away for good. :)
So there is:
I derive it:
Huh?! With respect to what variable are you taking the derivative and why? Also, what is [itex]x[/itex] in the above equation?:confused:
Hhhmm
Evidently, I made the mistaken assumption that the "theta" was the variable. Probably, I am making this more complicated than it is supposed to be.
Well, if you have some function [itex]f(x)[/itex] and [itex]x[/itex] is small, then [itex]f(x)\approx f(0)+f'(0)x[/itex] right?
You know that the quantity [itex]\frac{v}{c}\cos\theta[/itex] is small, so why not call that quantity [itex]x[/itex]?
When you do that, you have [itex]\lambda'=\lambda(1+x)^{-1}[/itex] right? So define the function [itex]f(x)=(1+x)^{-1}[/itex] and expand about small 'x'...make sense?
The reason you don't want to use [itex]\theta[/itex] as your variable is because you don't know that [itex]\theta[/itex] is small, so you would need to keep all terms in the Taylor expansion, which doesn't help you at all.
Okay, I think I got it. After I expanded it, I got:
[tex]\lambda'=\lambda(1+x)^{-1}-\lambda(1+x)^{-2}+\frac{2\lambda(1+x)^{-3}}{2}[/tex]
x is small, so it is around 0
[tex]\lambda'=\lambda-\lambda x+\lambda x^2[/tex]
x is v cos (theta)/lambda
[tex]\lambda'=\lambda-\lambda\frac{v}{c}cos \theta+\lambda(\frac{v}{c}cos \theta)^2[/tex]
Well, it turns out I only need the first order expansion in order to get a parallel equation with wavelength:
[tex]\lambda'=\lambda(1-\frac{v}{c}cos \theta)[/tex]
So, I think I got it! Thanks for the help. :smile:
Looks good to me!:approve:
