Fourier Analasys - Inner Product Spaces
This discussion focuses on two assignments related to Fourier Analysis and inner product spaces. The first assignment involves demonstrating that the sequence of functions fn(t) converges to 0 in L2[0,1] but does not converge uniformly. The second assignment requires finding the L2[-π, π] orthogonal projection of the function f(x) = x² onto the space Vn spanned by the orthonormal basis {1, sin(jx)/√π, cos(jx)/√π} for n = 1, 2, and 3. Key insights include the importance of understanding uniform convergence and the structure of orthogonal projections in L2 spaces.
  • Understanding of L2 spaces and convergence concepts in functional analysis.
  • Familiarity with Fourier series and orthogonal functions.
  • Knowledge of inner product definitions and properties.
  • Ability to perform integration and normalization of functions.
  • Study the definition and properties of uniform convergence in functional analysis.
  • Learn about orthogonal projections in Hilbert spaces, specifically L2 spaces.
  • Explore the derivation and application of Fourier series for various functions.
  • Investigate the normalization process for orthonormal bases in L2 spaces.
Students and professionals in mathematics, particularly those studying functional analysis, Fourier analysis, or anyone working with inner product spaces and orthogonal projections.
Ylle
I have two assignments I have some problems with.
The first one:
For n > 0, let
fn(t) = {1, 0 [tex]\leq[/tex] t [tex]\leq[/tex] 1/n
0, otherwise
Show that fn [tex]\rightarrow[/tex] 0 in L2[0,1]. Show that fn does NOT converge to zero uniformly on [0,1]
The second one:
Find the L2[-[tex]\pi[/tex], [tex]\pi[/tex]] orthogonal projection of the function f(x) = x2 onto the space Vn [tex]\subset[/tex] L2[-[tex]\pi[/tex], [tex]\pi[/tex]] spanned by
{1, sin(jx)/sqrt([tex]\pi[/tex]), cos(jx)/sqrt([tex]\pi[/tex]); j =1,...,n}
for n = 1. Repeat this exercise for n= 2 and n = 3.
For the first one, I will take the integral:
|fn|2 = int(0 to 1/n) (1)^2 dt = 1/n - and therefor it converges to 0 for n -> infinite.
It's the second part of this I'm not sure about. I'm not sure how to explain it. Any help ?
For the second one, I first test if the basis' is orthonormal, but first taking the inner product of each of them <1, sin(jx)/sqrt([tex]\pi[/tex])>, <1, cos(jx)/sqrt([tex]\pi[/tex])> and <sin(jx)/sqrt([tex]\pi[/tex]), cos(jx)/sqrt([tex]\pi[/tex])> to find out they are all = 0.
And then I take the inner product of every basis <1,1>, <sin(jx)/sqrt([tex]\pi[/tex]), sin(jx)/sqrt([tex]\pi[/tex])> and so on, to find out that 1 is not 1, but 2*pi. So I normalize that one by dividing it with the 2*pi, and then I have an orthonormal basis, since the other to are have the length 1.
And then to find the orthogonal projection I say:
<x2, 1/(2*pi)>1/2*pi + <x2, sin(jx)/sqrt([tex]\pi[/tex])>sin(jx)/sqrt([tex]\pi[/tex]) + <x2, cos(jx)/sqrt([tex]\pi[/tex])>cos(jx)/sqrt([tex]\pi[/tex])
And since I do it for j, and not a 1, 2 or 3, I guess I really don't need to show it for 1, 2 or 3, since it's only some different integrals that make the difference +
Well, I hope you can help me a bit.
Regards
For problem 1, showing that the convergence is not uniform is very easy. I don't say that to make you feel bad, but rather as a hint. What is the definition of uniform convergence?
For problem 2, the answer in the n=1 case will be a sum of 3 terms, in the n=2 case a sum of 5 terms, and in the n=3 case a sum of 7 terms. I couldn't tell whether or not you realized that.
Perhaps someone else can comment about whether your use of 1/2π instead of 1 is correct, because I always use the convention 2π=1 (just kidding a little, but not completely). Maybe you should use 1/√(2π).
  • · Replies 16 ·
