Some confusion on electron volt
The discussion revolves around the concept of electron volts, specifically the definition and implications of kinetic energy for an electron moving through a voltage difference. Participants explore the relationship between voltage, electric fields, and kinetic energy, considering both classical and relativistic perspectives.
  • Conceptual clarification, Assumption checking, Mixed
  • Participants discuss the definition of an electron volt and its relation to kinetic energy, questioning whether classical or relativistic formulas should apply in different scenarios. There is an exploration of the implications of using non-relativistic equations in high-speed contexts.
The discussion is active, with participants providing insights into the definitions and conditions under which different energy formulas are applicable. Some participants express confusion about the transition from classical to relativistic energy considerations, while others clarify that the definition of an electron volt remains consistent regardless of the energy formula used.
There is an emphasis on the definitions and assumptions related to kinetic energy in electric fields, particularly in the context of homework constraints that may limit the exploration of certain advanced topics.
dragonlorder
I learned that by definition, one electron volt is the kinetic energy an electron would have moving between 1 voltage difference. if an electron moves between voltage of 1 million volts,then K = 1MeV, for example, but the problem is K is expressed in 1/2mv^2 or the relativistic one (gamma-1)mc^2
In an electric field E the electron experiences a force F = e*E
Due to this force the electron moves a distance x, and the work done W = e*x*E.
This work produces kinetic energy in electron = 1/2*m*v^2
If the electric field is uniform Voltage = x*E
oh, so its defined in classical sense. I thought that since relativistic one was correct, so it might be the relativistic energy, but no. Thanks ~
No, for relativistic energies the relativistic formulas must be used.
1/2 m v^2 only works in non-relativistic situations.
yea, later I found out any electron moving through 1V, must carry 1eV energy by definition, doesn't depend on which formula I use. In high speed, relativistic, of course
  • · Replies 44 ·
12K
