Creating a "Coke Bottle" Rocket with Volatile Fuel
  • Context: NASA
  • Thread starter Thread starter Cummings
    Fuel Rocket
The discussion focuses on the creation of "Coke Bottle" rockets using volatile fuel instead of water to enhance thrust during launch. The user proposes using compressed air to expel a volatile liquid, which, upon ignition outside the bottle, generates thrust through gas expansion. Key considerations include the potential for increased thrust from combustion and the risk of instability due to thrust being generated at the tail end of the rocket. The user acknowledges concerns about the durability of the rockets and the need for more robust launch pads.
  • Understanding of basic physics principles related to thrust and gas expansion
  • Familiarity with rocket propulsion concepts
  • Knowledge of volatile fuels and their combustion properties
  • Experience with constructing and launching bottle rockets
  • Research the properties of various volatile fuels suitable for rocket propulsion
  • Learn about the physics of thrust generation in rocket design
  • Explore safety measures for handling and igniting volatile liquids
  • Investigate materials for building durable launch pads for bottle rockets
Aerospace enthusiasts, hobbyist rocket builders, educators in physics, and anyone interested in enhancing the performance of bottle rockets through innovative fuel use.
Cummings
Had a little project a while back, created some 'coke bottle' rockets.
The ideais simple, use compressed air to push out an incompressible liquid, water creating some thrust for the bottle rocket to fly into the sky.
there are plenty of tutorials for making bottle rockets out there, but i wanted a more realistic effect of a rocket.
Here is where some physics comes in. I personaly don't see this effecting lift off performence but i am no professor.
I want to replace the water, with a volatile liquid. And, when launched, the air forces the liquid out as it would do to water thus creating some thrust, but then the fuel coming out is ignighted, creating a rocket like effect on the ground and while it flies into the air.
As its ignighted outside the bottle, it wouldn't increase the thrust would it? If it were ignighted inside the bottle (well that's a generalisation), it would, as the expansion of gases would make a good little rocket.
Just somthing i want to test out to make the bottle rockets a tad more interesting. I fear that each rockets lifetime would drop dramaticly. That and i would be replacing launch pads quite a few tmes before i upgraded to a copper.
Actually, igniting fuel outside the bottle should still generate thrust. The expansion of gases as they cumbust should send a pressure wave out in all directions, including the direction from which the fuel just came. This would send pressure, and therefore thrust, upward into the bottle. However, it might also bad instability as the thrust would be coming at the very tail of the rocket.
  • · Replies 24 ·
  • · Replies 20 ·
  • · Replies 24 ·
